Antenna question guys
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Hugo Sanchez, Feb 5, 2015.
  1. Hugo Sanchez
    Hugo Sanchez Member
    30
    63
    LA 323
  2. Harris_BRG
    Harris_BRG Junior Member
    40
    Houston
    I believe the size is a bit different. Other than that I think it's just shape. The first one is more pointy. The second has more rounded edges.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I've been meaning to get a Shark Fin antennae since I bought my Prius, but I keep putting it off.
    I did do some research, in anticipation of making the choice I never seem to get around to making.
    And IMO the general consensus is no consensus. Both those products have their supporters and detractors. So I'd say the overriding factor should be which one you visually like best.
    Because reviews on both are across the board, with "unsurprisingly" most people supporting the choice they happened to make.
  4. Xterra72
    Xterra72 Senior Member
    1,432
    1,679
    Beatsonic is definitely larger.
    The shark fin antenna is suppose to look more like toyota oem, Like the ones you see on the lexus.
    I myself have the Beat Sonic. I have had no problems with it.
  5. Hugo Sanchez
    Hugo Sanchez Member
    30
    63
    LA 323
    Nice thanks anyone have the other one that can give me their take on it?
  6. Accordlayingkit
    Accordlayingkit Senior Member
    1,616
    1,747
    377
    Colonial Heights, Va
    I have the shark fin from the PriusChat store. No issues with that one either. There's a pic on page 1 of my build page which is below in my signature
  7. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I'm not impressed with the HD reception of the stock antenna. I'd be curious how aftermarket ones compare.
    That said, I'm also not impressed with how un-aerodynamic the shark fin antennas are. They'd likely have lower wind resistance mounting them backwards.
