Cells & Years
Discussion in 'Gen 2 Prius Main Forum' started by hybridbatt, Feb 5, 2015.
  1. hybridbatt
    hybridbatt Junior Member
    52
    Northampton UK
    Hi all, I am gradually piecing together an idea of what cells are in what generations, I know for example the Gen 0 has cylindrical cell sticks identical to the honda insights & civics so thats fine.
    Then there is the gen1 which went over to the better prismatic type as did the gen2 - I am told when gen 1 s tire out its a good idea to replace with gen 2 cells but you have to change them all i gather.
    Does the gen 2 go up to 2009?
    If any one knows how to link this post over to the other generation forums please do so.
    Thankyou
    Hybridbatt
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    No every block should be the same. Block consists of two modules. So you can build your battery by combining two different kinds of modules as long as every block has one of each.
    hybridbatt likes this.
  3. hybridbatt
    52
    Northampton UK
    Do you mean 2 banks of batteries as in - seperated by the service plug so for instance if you had 40 cells in all you could do half in original & half in gen2's
  4. valde3
    2,002
    750
    Finland
    No. Simplest to explain way would be to have every other module from gen1 and every other module from gen2. But this is only useful if your gen1 still has half of the modules good. And of course you need to the balance the battery.
  5. hybridbatt
    52
    Northampton UK
    Oh ok thankyou thats good to know so it has to be every other does it , is that right or am i getting confused?
  6. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    I think (perhaps someone will expand this) the main difference in the GenI and GenII modules is the case. Plastic vs. metal, the latter supposedly making for better heat dissipation than the former. They have close to the same physical dimensions. There is not much difference on the innards, with the same terminal characteristics.
    #6 nh7o, Feb 5, 2015
  7. hybridbatt
    52
    Northampton UK
    That is what i was hoping to hear, allthough round about october last year i helped a gen 1 owner & i am pretty sure the case in hers was metal as I remember - however it seems hopefull regarding its innards. many Thanks
  8. nh7o
    1,686
    340
    Hawaii
    Here are some photos of the Gen 1 and Gen 2 modules. The Gen 1 looks like plastic, with the Gen 2 clearly metal.
      File size:
      107.7 KB
      381
      File size:
      23.4 KB
      424
  9. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    The Prius battery is monitored by the HV ECU. It does this by monitoring pairs of modules (12 cells). The voltage of each pair of modules must be within certain limits the same as the other pairs of modules both on and off load.
    Because gen1 modules have a higher internal resistance than gen2 if you pair up some gen2 modules against paired gen1 modules under load the voltage of the gen1 pairs will sag more and trigger out of balance codes.
    If you pair one gen1 with one gen2 module for every pair (called a block) in the battery the voltage drop will be the same for all the pairs (blocks) under load providing they are all good modules. For the gen1 this would require 19 gen1 and 19 gen2 modules.
    John (Britprius)
    beradical likes this.
  10. hybridbatt
    52
    Northampton UK
    Yep I've got it now thanks for explaining it john
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    I'm disappointed.
    When I saw the title I thought this thread was going to be about hard time in prison.
    beradical and valde3 like this.
  12. hybridbatt
    52
    Northampton UK
    Is there any info out there about removal of the gen 0 battery pack ??
  13. Britprius
    5,194
    1,922
    There is precious little information on the gen 0 because as I understand it they were built for the Japanese market only. (I could be wrong). So those that did reach us are imports. You could be the person to educate us on this, and possibly have a go at fitting gen2/3 modules in the gen 0 case.
    John (Britprius)
    #13 Britprius, Feb 6, 2015
  14. hybridbatt
    52
    Northampton UK
    Blimey that's a challenge & a half John - I guess it will end being a case of is the car itself worth it. If I do I will do my best to document it for all on here
    Britprius likes this.
  15. Britprius
    5,194
    1,922
    Both modules are plastic but the gen2 module have a thin metal plate on each side to improve conduction for cooling.
    John (Britprius)
  16. Britprius
    5,194
    1,922
    The gen 0 is going to be a classic car. If the old Fiat 500 can fetch £12,000 the first real production hybrid is going to be worth a lot more. Particularly as there were a lot less gen 0's built.
    John (Britprius)
    valde3 and hybridbatt like this.
  17. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    776
    363
    The metal on the sides is more like foil molded into the plastic. It is extremely thin. I'm pretty sure all it does is spread the heat around evenly to provide better cooling.
    Avi
  18. marxatax
    marxatax Junior Member
    Pacific
    1999 Prius
    This is an interesting idea, however there is a practical problem: the gen2 modules are 10 mm longer at the top than the gen1 modules so that the bus-bars that connect the blocks together do not fit. This is why it has to be all gen1 or all gen2. Gen1 cells are hard to get these days.
  19. marxatax
    Pacific
    1999 Prius
    There is a world wide user group for gen 0, which they call Mk1, which has a lot of useful information about this vehicle. A search for 'Mk1 Prius' should find it. According to Wikipedia there were about 35,000 of this model produced, all for the Japanese market only. 'Grey' imports account for the gen 0's presence in UK, Australia, NZ, Russia and other countries.
    Some people on that group have tried installing gen2 or later modules in the gen 0 but there are many practical difficulties. The easiest solution is to get a new set of battery sticks (40 in a set) out of China, which is rather expensive but effective.
    Regards,
    Angus
  20. hybridbatt
    52
    Northampton UK
    The worst of all suppliers from China are King Kong I have had 2 very bad experiences with them so please anyone watching this thread avoid them like the plague!!
    The welding is terrible quality more akin to model aircraft standard - under moderate load hot spots & melting sleeving appear. Honestly awfull & very dangerous customer service awfull too
