Engine coolant change DIY video posted
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by jreed, Jan 26, 2015.
  1. Patrick Wong
    18,200
    6,492
    The correct tightening torque is 29 ft.-lb. Use a cheater bar when loosening the drain plugs, that makes removing the plugs very easy.
  2. stonerider
    stonerider Member
    107
    Lompoc, CA
    What's a cheater bar?
  3. xliderider
    xliderider Senior Member
    8,041
    3,214
    Honolulu, HI
    It's a section of pipe that you slip over the wrench handle to lengthen it to give you more leverage. Works especially well on stubborn wheel lug nuts. ;)
  4. Mendel Leisk
    40,530
    Or get a breaker bar, basically a socket wrench with a longer arm, designed for that purpose.
  5. Patrick Wong
    18,200
    6,492
    Yes, a breaker bar is better than a cheater bar used with a ratchet wrench. The latter may damage your ratchet wrench if excessive force is required.
    I have breaker bars for 1/2" and 3/8" sockets, and lengths of pipe (cheater bars) that will fit over the breaker bars and extend their lengths, thus preparing me for all reasonable possibilities. This is especially useful when doing suspension work.
  6. Mendel Leisk
    40,530
    An impact wrench is best I guess? Never got into it though, not enough use and don't know the first thing about compressors.
  7. Patrick Wong
    18,200
    6,492
    Well, the tightening torque is only 29 ft.-lb so an impact wrench would be overkill and that wrench wouldn't fit in certain places, for example the ATF fill plug on the transaxle case. The use of appropriate hand tools is very reasonable.
  8. liveinmtl
    liveinmtl New Member
    montreal
    Much appreciated. Where to buy the coolant bleed hose?
  9. Mendel Leisk
    40,530
    Any hardware store should have an assortment of diameters, vinyl tubing I think it is. Try to accurately measure the bleed bolt before going in, bring along a drill bit in that diamter, to check fit.
    FWIW, I never connected a hose when refilling coolant on various vehicles over the years: just open the bleed bolt, pour coolant until it started coming out of the bleed bolt, then quickly closed it. You spill a tablespoon or two at most.
    Raytheeagle and Patrick Wong like this.
