Engine question - inspect or not ?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by SvMi, Feb 6, 2015.
  1. SvMi
    SvMi New Member
    Hi all !
    First post to the forum.
    I've been eyeing this forum for quite a while and have learned a lot about my Prius C (6 months old)
    I love this damn car.. perfect for almost anything ! I've road tripped with the car packed (tent/sleeping bags/coolers/two mountain bikes/etc) with no issues.. Recently bought a Curt hitch receiver so it'll be awesome to get a hitch based rack.
    At first, I was getting around 60MPG sticking below 60MPH with P&G involved and it's pretty warm here in California.
    Now I'm getting around 45MPG (I feel silly complaining about that although it's a big step down)
    My MFD during my drive around 60MPH shows that the electrical motor is not constant as the green arrows comes on/off during a constant actuation of the gas on a level freeway via MFD; I can't actually confirm via naked eye. Sometimes, it shows that the electrical/green arrows is not transferring power at all which I have to alleviate by depressing pedal and actuating gas again.
    Here is my chrono history/checklist
    -Recently rear ended which was fixed by Toyota (hopefully.. they had to reset the computer as the airbag deploy indication kept flashing)
    -Recent 0w20 oil/filter change (I made sure to use OEM)
    -Recent engine/cabin filter change (OEM)
    - Checked rear vents to make sure it's not covered up
    Wanted to see if anyone can shed some light before I pay for an expensive diagnosis.
    Sounds normal ??
    Thanks !!
    51,023
    welcome! how are you measuring mpg's? 6 months old, meaning you bought a new 2012 off the lot in september of 2014? how many miles on her? everything sounds normal except your mpg's. you might want to test your 12 volt battery. how extensive was the accident? how much the repair cost? did you notice the mpg drop right after the accident, or subsequently? a lot of questions, i know, but we'll need a lot more info to help you.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Are you still under warranty?
    Since looking at your timeline I surmise you bought used and admit to recently being involved in a rear end collision, I'd definitely want that expensive diagnosis.
    Mileage always drops with the extremes of winter. But that's a pretty steep drop.
    All the usual recommendations apply. Tire Pressure?
    But in general, I want to say California temperatures? And maybe because the vehicle has recently been involved in collision, I'd want everything checked out.
    How about alignment? A collision can knock that out of kilter.
    Good Luck, I hope you find what has caused this sudden drop in MPG.
  4. SvMi
    SvMi New Member
    Hi all,
    Thanks for the prompt replies !
    Please find answers below:
    1. Full tank-almost empty and some math
    2. Quick overlook at the ODO MPG (as trip mpg just shows the MPG of the whole trip A or B)
    I plan on getting a Scan Gauge soon ! Hopefully it'll help.
    Used
    44K
    It's driving me nuts :( at first I thought it was just me. How do I test the 12 volt battery ?
    Rear ended on the freeway although it didn't leave any marks (strong thing !)
    I just had the rear bumper replaced and computer reset to turn off the airbag deploy sign.
    Covered through the other party (insurance)
    Around 2K
    Seems that way.. it happened 1-2 months after the accident.
    Only warranty available: Toyota certified pre-owned warranty = 7yr/100k miles
    It gets hot in LA ;)
    40F / 38R
    Never had an alignment check :(
    Thanks !!
  5. Mendel Leisk
    40,467
    Could it be those bikes, air drag?
  6. SvMi
    SvMi New Member
    Bikes are always inside :)
  7. Mendel Leisk
    40,467
    Wow, that's impressive.
  8. SvMi
    SvMi New Member
    If it helps.. here's a quick video of me going 64-65MPH constant on a flat freeway around the "0" of where ECO is on the tach.
    I'm not too sure what is considered normal when it comes to the electric motor kicking in and how long it should be on for..
    In the video, you can see that it goes off/on constantly and sometimes, it just stays off as previously stated.
    Anyone else experience this ? & can someone with a Prius C chime in on if this looks normal ?
    Thanks
  9. bisco
    51,023
    video looks normal, the car is constantly changing power flow for pollution control and mpg's. get a digital volt meter and put it on the battery after it has been off for a few hours. it should be 12.5 or better. certainly, your alignment should be checked after an accident. have you had all the normal maintenance for 45,000 miles? air filter, oil level, the usual stuff?
  10. SvMi
    SvMi New Member
    UPDATE:
    I put my car in service mode and checked the batt. It's 12.9 - 14 which is a good sign.
    I was just cruising around the menu and noticed some kind of reset (forgot the name) so I went through and reset everything.
    As I was just driving back home, I was averaging 62MPG city/ 59MPG hwy
    Sounds a bit more normal although does this sound like a familiar error ??
    Thanks
    PriusGuy32 likes this.
  11. bisco
    51,023
    maybe they did something when repairing the accident, and the reset fixed it. will be interesting to see what you get on the tank after you fill up.
  12. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    Wow, and I'd almost think they'd have to be foldable bikes to pull that off.
  13. SvMi
    SvMi New Member
    Yeap ! And I also had two sleeping bags/cooler/tent/portable butane grill & a bunch of blankets-pillows.
    I just filled up so I will report shortly.
    Thanks
  14. SvMi
    SvMi New Member
    eye balling the heck out of my gas, 1 bar down & 56.2miles.. I watch these videos of people getting around 70-80mpg on the C.. how is that possible ?!
  15. JC91006
    JC91006 Senior Member
    16,656
    8,504
    don't watch those videos of people getting 70-80 mpg. It'll set you up for disappointment.
  16. SvMi
    SvMi New Member
    I can never get those numbers...
    How about everyone else here on their Prius c ?
  17. JC91006
    16,656
    8,504
    To get that mileage, you would need to drive when the moon is fully round and have a tailwind of 50mph going down a 6% grade.
  18. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    I have a 50MPG lifetime average on my C after about 18,000 miles, calculated from actual fill-ups. I drive it the same way I drove the 1996 BMW 318ti hatchback that it replaced.
  19. SvMi
    SvMi New Member
    Thanks for the information ftl. I'm not feeling too crazy now..
    Mmm Bmw Ti... I plan on getting a BMW 2002TI 1974 rally project as my "weekend" dirt ride
  20. bisco
    51,023
    can you post one of those videos?
