PriusChat Software Update - 3/3/15 Discussion
Discussion in 'PriusChat Website Questions' started by Danny, Mar 3, 2015.
  1. kutztown46
    kutztown46 Junior Member
    31
    Kutztown, PA
    2022 Prius
    Mark, on my work computer (have not checked how things look on my home computer yet), I have an ancient Pentium computer but a fairly new and very large monitor (30" I think). Resolution is set to the maximum - 1360 X 768. I am using Internet Explorer 8 (no choice on my part). Before the software changes, this problem did not exist.
  2. Paradox
    29,110
    8,591
    201
    2014 Prius v wagon
    Hmm, I'm on a machine with a 30" screen right now and just set the screen resolution to 1360x768 from 2560x1440 and it still displays ok. I'm by far no expert in this though so unfortunately I can't offer a fix for you. Maybe others or Danny will have more input.
  3. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    No overlap on a Chromebook either.
    I will say though that the poster information takes up a lot of space. This results in short posts having a lot of white space until the following post. Not the end of the world to be sure, but not aesthetic or functional.
    I use the spacebar to scroll down, shift-spacebar to scroll up
    #23 SageBrush, Mar 5, 2015
  4. Yakoma
    Yakoma Active Member
    470
    125
    sss
    Thanks, Danny...I like the new look-and-feel a lot. And I really like the post-by-post scrolling...saves my mouse button finger.
  5. Danny
    Danny Admin/Founder
    7,093
    2,117
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    Definitely sounds like an IE8 problem. Let me try a couple things and I'll post again once I'm done so that I can get your feedback.
    I don't disagree with this, @SageBrush. Still working on it to make it more functional. I wanted to highlight the avatars while presenting the other data in a more aesthetic way. So far I've failed.
    @Tideland Prius, thanks for pointing that out about the post scroller. I'll see if I can figure that out.
  6. wjtracy
    wjtracy Senior Member
    11,359
    3,606
    Northern VA (NoVA)
    Yes the avitar is real big on IE8 on XP, you can go to Firefox or presumably Chrome.
  7. kutztown46
    31
    Kutztown, PA
    2022 Prius
    Unfortunately, I have no choice on my work computer. I do not have the ability to use a different browser. If I did, I would use Chrome, which is what I use at home.
  8. SageBrush
    11,627
    2,533
    Southwest Colorado
    Smaller font ?
    The photo is what I see on a Mac using Safari or with a Chromebook
    #28 SageBrush, Mar 5, 2015
  9. Fore
    Fore Don't look back!
    494
    107
    Didn't check if this has been addressed already but I just wanted to let you know I couldn't login to PriusChat using my usual password for some reason so I had PriusChat email me a temporary new one. Well it won't let me change the password once I'm in.
  10. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    Yes, I agree exactly. That did not occur until the recent revisions. The huge fonts for titles waste a lot of screen space, as do the larger white spaces.
  11. Tideland Prius
    16,428
    Learned something new! I did not know about the shift+spacebar shortcut. Thanks!
    The post-scroller feature at the top jumps exactly from post to post.
  12. SageBrush
    11,627
    2,533
    Southwest Colorado
    All the web browsers I use work this way. It is not site specific.
    It has actually become something of an annoyance for me, because my fingers are so used to the behavior I get unexpected results in other programs ;)
    Tideland Prius likes this.
  13. kutztown46
    31
    Kutztown, PA
    2022 Prius
    The pictures / avatars look fine on my home computer using Chrome. So it is definitely related to IE8.
  14. hill
    8,621
    surprise of all surprises - it finally works! And no, I don't mean just side loaded. It's actually working without having to monkey with it. I had all but given up on tap a talk. Yet, here I am ... A tappin' and a talkin'. Good job. Here's to hoping the next down time will be a little shorter.
  15. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
  16. Tideland Prius
    16,428
    @Danny the post scroll looks to be fixed now. It stays where it should be from the top to the bottom of the page.
  17. orenji
    orenji Senior Member
    5,886
    3,487
    What's the blinking green circle on the avatar for?
  18. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    If you hover your cursor over it, a box will pop up to tell you it means that member is currently on line.
    orenji and ftl like this.
  19. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    Perhaps we're looking at two different places! Here are screenshots from the New Posts screen; the first one is when it loads and the second one after I scroll down one notch. The main menu bar remains at the top of the screen but the "Mark Forums Read" line immediately disappears.
  20. Danny
    Danny Admin/Founder
    7,093
    2,117
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I believe Jon was referring to the post navigation (the "19 OUT OF 19") that you see at the top that allows you to skip through posts easily. I believe you're referring to the navigation submenu. I'll see about making that sticky. Or at least pop back up when you start to scroll up.
    ftl likes this.
