scangauge, need help with xgauge
Discussion in 'Gen 3 Prius Accessories and Modifications' started by ramattos, Mar 7, 2015.
  1. ramattos
    ramattos Junior Member
    57
    Bethlehem PA
    just got it today but the document that i got doesnt show a specific code to input for the engine temp. do you just use the one for alt coolant temp? if not what is the correct one. also what other gauges are practical for keeping on all the time.
  2. Xterra72
    Xterra72 Senior Member
    1,435
    1,681
    These are what I have on at all times
  3. Tony D
    Tony D Active Member
    469
    132
    Dublin, Ireland
    And they are
    Battery Voltage
    MPG
    Engine temp
    And .....
  4. Xterra72
    1,435
    1,681
    Intake air temperature. Temperature of the air going into the engine.(y)
    Tony D likes this.
  5. Robert Holt
    Robert Holt Senior Member
    1,313
    889
    You should have a small manual that explains how to program in the Xcodes. I am monitoring engine water temperature, which was a "default" code available right out of the box--FWT stands for degrees Fahrenheit water temperature. I also have monitored GPH which is gallons of gasoline per hour fuel consumption. My other two fields had to have the Xcodes laboriously programmed in digit by digit and they have the acronyms BT2, which is the number two temperature probe on the High Voltage battery which usually runs highest, and BFM which is an indicator of the Battery Fan Motor, from level 0(off) to 6(max). I use the last two fields to detect heat stress on the HV battery--the combination of higher temps and higher fan speeds tells me to minimize load on that battery and increase cooling by using AC in the cabin, etcetera.
    Good luck with yours!
  6. cproaudio
    cproaudio Speedlock Overrider
    2,401
    762
    CA
    Goto the scangauge website and look for Prius xgauge
