Prius Headlight Modification.
Discussion in 'Gen 3 Prius Accessories and Modifications' started by dhman2006, Feb 27, 2015.
  1. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    I have a 2011 Prius II and the lights don't seem to work too well for me at night. I'm trying to modify these lights. What would be the best option for me? What bulbs should I buy or what modification should I do/ consider in order to see better at night. If someone can help me out that'd be great.
    Thanks.
  2. Starbrand
    Starbrand Senior Member
    493
    1,503
    Westmont, IL
    do you have a pic? the headlights probably just need to be cleaned with this:
    otherwise, can always upgrade to HIDs :D a lot of people will refer you to The Retrofit Source Inc
    this is what I bought, and they work great:
  3. xliderider
    xliderider Senior Member
    8,131
    3,268
    Honolulu, HI
    Upgrade your 55w H11 halogen bulbs to 65w H9 halogen bulbs. Two easy modifications on each H9 bulb need to be done, link in my signature below, for them to fit. Look for the excellent video at the end of the thread in the linked thread.
    Make sure you buy name brand bulbs like Osram or Philips. Stay away from cheap Chinese stuff, and get the ones with clear glass envelopes, not blue. Read the reviews on Amazon for the Philips H9 bulbs, many people have done the upgrade and are very happy with the mod. I have done this on both of my cars, and have not had any problems since January 2014.
    You can get Philips H9 bulbs from Amazon for about $20. Much less than the so called premium H11 bulbs.
    The H9 bulbs will give you approximately 50% more light than the H11 factory lights.
  4. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
    Would you recommend converting to HID?
  5. dhman2006
    dhman2006 Member
    162
    27
    Boston, MA
  6. Sfcyclist
    Sfcyclist Senior Member
    1,621
    375
    SF, CA
    I went the HID route and it works well HID kit work well in the Gen 3's. I've had mine for 2+ years and no issues.
  7. Sfcyclist
    1,621
    375
    SF, CA
    oh.. and look into TSB-0204-12 as well.
