Hella Supertone install today
Discussion in 'Prius c Accessories and Modifications' started by taylor5796, Mar 18, 2015.
  1. taylor5796
    taylor5796 New Member
    Georgia
    I think we all know our stock horns are junk. I cannot count how many times I've had people almost run me off the road because they can't see or hear me. Today I installed the Hella supertones. As you can see in the picture I posted there are perfect mounting holes in the chassis behind the grill for both horns. I grounded the new horns to the old horn mounting bolt.
    I can get get into more details if you like and more pictures as well. There is enough room down there for another set of horns. I'm very tempted to add them.
    All in all with the stock horn removed and the Supertones installed, my C is a screaming machine when I mash the horn. I am very pleased with the sound and loudness.
  2. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    I swapped out my stock horns for OEM Lexus Premium horns. The Lexus horns are much louder then stock. Stock is only one horn and the lexus is 2 horns.
  3. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    I installed a Wolo Bad Boy Air Horn which is very loud. Definitely get peoples attention.
  4. kingnba6
    1,018
    242
    NY
    Where did you place the Wolo? In the original location? Did you upgrade the wiring?
  5. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    I have a bracket on the front center of the engine compartment near the hood latch. I did not upgrade the wiring and have had it on there for 2 years now with no problems.
  6. taylor5796
    Georgia
    I figured why not just add the relay that came with the Supertones. It may or may not have made a difference right now but if I go forward with installing an additional pair for a total of 4 horns then I'll be glad I have the relay.
    Plus with the current set up I have, I didn't have to modify the factory harness to accommodate the 2nd horn.
    When the rain stops I'll post some install pictures and a video of the horn sound.
  7. kingnba6
    1,018
    242
    NY
    Nice. I would love to see a picture. I might upgrade to the Wolo horn someday.
    When I upgraded from stock horn to dual Lexus horns, I just used the original wiring without a relay. I also had to splice another connector from the OEM wire. But for 4 horns, I would use a relay without a doubt.
  8. yOsHi LiN
    yOsHi LiN Active Member
    215
    138
    los angeles
    2014 Prius c
    i did the same but sickspeed !!! i dont like how it sound but just the look !!!
  9. SamanthaC0716
    SamanthaC0716 Active Member
    333
    115
    I have Sickspeed horns sitting in my garage, waiting to be installed. Why don't you like how they sound? Are they not louder than stock?
    iPhone ?
  10. xliderider
    xliderider Senior Member
    8,032
    3,211
    Honolulu, HI
    Are they dual tone (hi/lo)? If they aren't, that may be the reason.
  11. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    yeah they are louder, but who really uses the horn
  12. yOsHi LiN
    215
    138
    los angeles
    2014 Prius c
    yeah they are dual tone, but it kinda sound like a go kart
  13. SamanthaC0716
    333
    115
    Mine are in. I'd recommend the Sickspeed. I like how they look and sound. (They don't come green. I painted them that color.)
    iPhone ?
    Starbrand likes this.
  14. orenji
    orenji Senior Member
    5,886
    3,487
    I have yet to look, but does the C only have one OEM horn?
  15. xliderider
    8,032
    3,211
    Honolulu, HI
    I believe that is so.
    orenji likes this.
  16. orenji
    5,886
    3,487
  17. kingnba6
    1,018
    242
    NY
    My C1 only had one horn.
    orenji likes this.
  18. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    The photo in this post shows the location of the single horn (removed ready to install twin FIAMM)s:
    carfart horn | Page 2 | PriusChat
    orenji likes this.
