Back-up sensor
Discussion in 'Gen 3 Prius Accessories and Modifications' started by evebill8, Apr 2, 2013.
  1. Garen
    Garen Junior Member
    63
    Sherman Oaks
    2019 Prius
    You got a point there.
  2. nufan2222
    nufan2222 Junior Member
    96
    2014 Prius Plug-in
    you guys realize that these kit only cost 10 bucks right? ANd labor isn't hard
  3. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    The last one I installed on my previous car was from Scosche where I didnt have to drill holes and the sensor itself was a long foil that went across the inside of the rear bumper.
    On another note, so you have to deal with two beeps now? One from the camera and another from the backup sensor? Just wondering... Thanks guys :)
  4. kenniekenken
    kenniekenken Member
    105
    60
    Alberta
    I installed one for a friend and got it for $30.
  5. xliderider
    xliderider Senior Member
    8,140
    3,278
    Honolulu, HI
    The factory beep can be changed to one beep when reverse is engaged, instead of the constant beeping.
  6. nufan2222
    96
    2014 Prius Plug-in
    You can turn off the reverse beep by using the OBD2 techstream
