Coolant Control Valve (safe to drive?)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by electricturd, Mar 23, 2015.
  1. electricturd
    electricturd Junior Member
    nc
    My wifes 2008 prius check engine light just came on. Its the control valve sensor. My question is, does that have any serious impact on safety? We are going to Florida next week from NC and i'm wondering if it should be fixed before we go. I've heard mixed on what this valve does (overheating etc).
  2. jdenenberg
    jdenenberg EE Professor
    3,935
    1,933
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Make certain that you are not low on coolant. The coolant acts as a lubricant for the valve and a p1121 can be triggered by low coolant. Did you recently have the coolant drained and refilled? If so the mechanic may not have gotten all of the air out of the system and now that the trapped air has been released, the coolant level is lower.
    JeffD
  3. electricturd
    nc
    Thank you, I checked the coolant level (tank next to radiator?) and it appears to be fine. No maint on coolant system recently at all.
  4. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Checking the tank next to the radiator is of no use. You must check the radiator it's self, and it must be full to the brim. There are circumstances where the expansion tank does not refill the radiator.
    Fill only with Toyota SLLC.
    John (Britprius)
    Hanging on with 286k likes this.
  5. electricturd
    nc
    Alright, I'll check that later today. Assuming thats full whats next?
  6. Britprius
    5,194
    1,921
    If it is full it is perfectly safe to drive, but there is the downside of the warning light masking other faults that "however unlikely and not associated" may appear.
    If the system is low top it up with Toyota SLLC coolant, and then disconnect the 12 volt battery for a few minutes to remove the code. Then see if it reappears.
    John (Britprius)
  7. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    I've been driving with the p1211 code for a little over a year now with no problems. There was another poster who had over two years on the same code no problems. Britprius has a good point you can't tell if there are other problems popping up, though there was a user on here (can't remember his handle) but he stated, comically or otherwise I do not know, that the first thing you do when you buy a Prius is you take a screwdriver and punch out the engine light on you car! I purchased the control valve online and saved quite a bit of money over the dealer, I just haven't put it in yet. The dealership wanted three hours labor for the job...
    GrGramps likes this.
