Smart Key Programming for 2010
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by pfhyper, Mar 3, 2015.
  1. CR94
    CR94 Senior Member
    2,660
    1,149
    Northwestern S.C.
    Good suggestions. You could keep a spare fob battery hidden separate from the fob in the car, preferably in a relatively cool location.
  2. Trixie LaRue
    Trixie LaRue Junior Member
    Update - I got the fobs from eBay and they were new, never programmed (confirmed by locksmith). They had the extra button which I expect was for the V. I took them to the best known locksmith in Salt Lake - Glen's and got both fobs programmed and both laser keys cut for $110. At that price it wasn't worth my time to buy the cable and try it myself. So, all totaled, I paid $278 for 2 new fobs all programmed and cut. I think I did OK.
    2DMaxLST likes this.
  3. pfhyper
    pfhyper Junior Member
    Minneapolis, MN
    That's a great deal! What symbol was on the extra button and are the keys for a 2010 Prius?
    And can you share the ebay link where you purchased them?
    Thanks.
    #23 pfhyper, Mar 12, 2015
  4. Trixie LaRue
  5. pfhyper
    Minneapolis, MN
    And you were replacing a 3-button smartkey for a 2010?
  6. Trixie LaRue
    Yes. Only need the 3 buttons. Nothing happens if I press the hatchback.
  7. Mendel Leisk
    40,469
    I would check other dealerships. For a few scary hours over the weekend we lost track of one fob, and I emailed our nearby dealership, their service manager, asking how much. His response, still painful, but less than your quote. And this is Canada, home of high prices. How much less, not exactly sure: is your number inclusive of taxes? Anyway, his response:
    Hi Mandel
    FIND that key!
    The transmitter and key (cut to code)
    Is 372.40 plus taxes
    (can be order the same day)
    With our 12% tax added it comes out to $417. Again, that's Canadian bucks, and we usually seem to pay 20% more. That was the only dealership I contacted, and I've found one that is a bit of a drive but undercuts them usually by ~10%.
  8. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    728
    Boulder Hybids, Boulder, CO
    Mendel, did the price include programming the fob to your car? Many dealers charge 1 hour programming fee ~$115
    The price you were quoted may have only been for "the parts".
    There is no way to program Gen3 with a chicken dance, you need Techstream or similar.
    Also, if you lose all your fobs get ready to spend huge bucks at the dealer, + a tow.
  9. billley
    billley Junior Member
    Austin TX
    Has anyone tried duplicating a laser key on a 3-D printer?
  10. 3prongpaul
    956
    728
    Why not just get a proper "emergency" door key made? They are only $16.95 delivered once you retrieve the code. All you need is a couple minutes and a Torx 30 screwdriver to retrieve the code from your door lock cylinder. Pay with Paypal, it arrives a couple days later in the mail. see Toycut - ovnisf Keys for video on how easy it is to remove door lock cylinder.
    Robert Holt likes this.
  11. pfhyper
    Minneapolis, MN
    We found a local locksmith who said he could program used smartkeys so I ordered two from eBay. Checked ALL the code numbers, even the one on the IC board inside. They all matched and seller said it should work.
    The smartkeys weren't the issue. The locksmith said his scan tool (T-Code Pro) couldn't connect with the immobilizer in the vehicle itself. Without that connection, he can't program the keys. Not sure if that's an issue only with used keys or not.
    Luckily I can return the keys.
    Anyone ever heard of this?
    Peter
  12. 3prongpaul
    956
    728
    If the LED works on the Fobs it's unlikely a problem with the Fobs.
    The only thing that could prevent his tool from talking to the car is a blown OBD fuse, under the dash fuse panel. It's probably a 7.5 amp. (or his equipment is not good) Did the locksmith say he's actually done a Gen3 Prius before or just thinks his equipment can do it?
    Before sending fobs back, ask these guys Foreign Auto Repair | The Foreign Service if they have Techstream. If they have Techstream they can do it with a little assistance from me. Tell them Paul from Boulder Hybrids sent you.
  13. pfhyper
    Minneapolis, MN
    Expect a call from Chris at Foreign Auto Repairs. Thanks so much.
  14. pfhyper
    Minneapolis, MN
    Locksmith did say he has done 2010 Prius's and this was the first time he has seen something like this.
    Peter
  15. Mendel Leisk
    40,469
    I checked on that: there'd be an extra $30~80 labour charge, depending on model/complexity. That's on top of $372.40. All numbers Canadian $'s, pre tax.
  16. John-117
    John-117 New Member
    Sorry if this is not the proper etiquette, not sure if it's better to start a new thread. I'm looking to get a new fob too and want to buy from a online toyota parts store, is this the correct part? Does anyone know if it includes a physical key blank for cutting?
    TRANSMITTER for 2010 Toyota Prius|89904-47150
    Thanks!
  17. Mendel Leisk
    40,469
    Good question, lol. Is there some rule on the books, that the description HAS to be cryptic/meaningless? What the heck is a "transmitter"? No visual aid either.
  18. pfhyper
    Minneapolis, MN
    I got my two used smartkey fobs programmed successfully at Foreign Service in Roseville, MN. 3prongpaul recommended them and was available to walk them through it. They couldn't cut the keys though and I probably paid too much for that part but oh well. As the dealer wanted $425 for a new key I feel pretty lucky.
    I'd link to the ebay item but they are all sold.
    #38 pfhyper, Mar 31, 2015
  19. golfinbud
    golfinbud Junior Member
    Bowie, Md
    Great post!
    Will 32bit Windows XP VM run alright on a Windows 7 laptop?
    Thanks.
  20. John-117
    John-117 New Member
    I'm 100% positive it will. Another option is to install techstream directly on 32bit Windows 7, which also works fine.
    Thanks
