Tire Rotation on Gen Two
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Fishcrab, Apr 3, 2015.
  1. Fishcrab
    Fishcrab Member
    152
    29
    i have just purchaced a 2005 with standard size Michelin tires. The dealer says rotate them front to back on each side. I know there has a lot of past dicussion on how best to rotate all4 tires. I keep 42psi in front tires and 40psi in rears. Should I do as the dealer recommends, heard you can get longer wear by criss crossing them.
  2. mikefocke
    3,939
    1,775
    Sanford, NC
    Are they directional? If they are, they have an arrow on the sidewall pointing in the direction of rotation.
  3. cyberpriusII
    1,153
    1,726
    Mars Hotel
    The manual says front-to-back. I do not earn what they pay the Toyota engineers, so I DO hope they earn it. So, I follow their instructions. Hope yours are not "welded" on as mine have been.
  4. Fishcrab
    Fishcrab Member
    152
    29
    They are not directional tires .
    Sorry bout your wheels or tires.
    I took my car to discount tires and the guy working their said they need to be criss crossed , I said no front to back, finally had to stop them from criss crossing . Tires may have 10k on them, no wear patterns.
  5. bisco
    51,492
    front to back is fine. you're just evening out the wear so you can replace them all at once.
  6. Fishcrab
    Fishcrab Member
    152
    29
    Thanks , good to know,
  7. Mendel Leisk
    40,934
    When I encounter "welded", which seems to happen more frequently with alloy rims:
    1. Have the offending wheel just an inch or so off the slab. (slab preferable, asphalt in a pinch, not so good on dirt)
    2. Place a 2x4 piece on edge behind the wheel at base.
    3. Leave ONE lug nut in, at a top location, and very loose, just enough to be secure.
    4. Take the largest sledge hammer you've got (or go shopping for a good sized one), lay it with head about 2~3 feet inboard of the 2x4.
    5. Swing it in an arc across the slab, aiming for 2x4 at centre of wheel.
    6. Repeat if needed with more force, but it'll usually break it loose the first time. The top lug nut keeps it from possibly taking off.
    Fishcrab likes this.
  8. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    I leave 1 lug on and just donkey kick the tire. if that don't work I have a big no-bounce plastic mallet and I wail on the inner side of the tire. that always works.
  9. cyberpriusII
    1,153
    1,726
    Mars Hotel
    Someone (or two or three someones -- Patrick Wong might be one?) told me that for welded wheels to just loosen all the nuts and drive down the street a bit. That has worked. Backing up a few feet and braking hard a few times worked once, but never again.
    Last time I rotated, I cleaned off all the gunk with a wire brush and put anti-seize on all the wheels -- that was in Jan. We will see what the summer brings. Of course, the cleaning and anti-seize was recommended by "whomever(s)" a few years ago, also, but at that time I was too lazy to take that extra step. Since then, I have "reformed."
  10. Patrick Wong
    18,200
    6,498
    There is nothing wrong with using an X rotation on non-directional tires. It is true that the Toyota maintenance recommendation is front to back on each side - and that procedure is easier to implement when DIY if you lift one side of the car at a time.
    However if you notice unusual wear on one side vs. the other, the X rotation will help to even out that wear. I've done that procedure on occasion. In that case, I would raise the front of the car using jack stands placed at the points intended for the scissors jack. I would raise the rear of the car at the center rear jacking point with a hydraulic floor jack (look under the car for the inverted "tower" pointing down, that is the center rear jacking point). Now all four tires can be removed and swapped around.
    #10 Patrick Wong, Apr 4, 2015
  11. Fishcrab
    Fishcrab Member
    152
    29
    Thanks Patrick, I will just start using the x rotation, makes since. I'm starting check my tourqe on lug nuts after leaving those places, finding some slight descrepencies. My car buddy friend says it's good to lube threads on studs, you think that's a good idea?
  12. Patrick Wong
    18,200
    6,498
    No, I do not. The torque spec does not assume lubricated stud threads. Just use a 1/2" torque wrench set to 76 ft.-lb when tightening. Use a 1/2" breaker bar if needed when loosening the wheel nuts.
    #12 Patrick Wong, Apr 4, 2015
  13. Fishcrab
    Fishcrab Member
    152
    29
    Thanks so much, will stay away from lube.
  14. Fishcrab
    Fishcrab Member
    152
    29
    Seems like 90 ft lb for torque in garages around these parts.But will change to 76 ft lbs,
    Does it vary on a lot of cars? The torqe for tires that is.
  15. bisco
    51,492
    probably depends on wheel size, material and such.
  16. cyberpriusII
    1,153
    1,726
    Mars Hotel
    Torque for the lug nuts is not all that important, I don't think as long as you are not off by whole lot. Having said that, I am sure I am wrong.
    If I remember correctly, when I was trying to find the torque for the Camry, I looked at a Dorman (I think) chart that had hundreds of car models and it listed lug nut torques that ranged from like 50 ft-lbs to something like 300 ft-lbs ... as Bisco said, depends on the vehicle.
    Before I bought my highly accurate and very expensive HarborFreight 1/2-inch torque wrench (seven dollars?), I always just jumped up and down on the lug wrench and called it good when I changed the tires around. Once I got the torque wrench, I managed to figure out my jumping up and down method resulted in a torque of around 80 ft-lbs. Which was close enough for me.
    So, now my torque wrench is in Oregon and I am in Iowa and I am back to jumping up and down on the lug wrench. No harm that I can see.
    BUT, as Patrick said, NEVER lube the lug nuts. It's a safety issue. I asked my mechanic about doing that several years ago and he looked at me in horror that I even suggested it.
  17. 69shovlhed
    2,170
    751
    Delaware
    most shops use an impact gun to put lugs on, so they will be tighter than spec. if the tech isn't a douchebag, he will use a torque stick so the lugs won't be way too tight.
    as far as lubing lugs: with open lug nuts or rusted or partially cross threaded studs, sometimes lube is a good thing. with prius lugs, you normally shouldn't ever need to lube the studs.
    #17 69shovlhed, Apr 9, 2015
    Fishcrab and cyberpriusII like this.
  18. cyberpriusII
    1,153
    1,726
    Mars Hotel
    My backwoods tire guy that I used for a few years always used the impact thing to get the wheel snug and then used a torque for final tightening. I think he had a different brand torque wrench than my HarborFreight model :D
    When I had Goodyear FuelMaxs put on at Sears some 15 months ago, I would be surprised if those guys even knew what torque was...
  19. 69shovlhed
    2,170
    751
    Delaware
    a lot of guys just don't care. only concern they have is that the wheel doesn't come off when your driving and then you sue them, so they crank em on extra tight with the impact.
    cyberpriusII likes this.
  20. Fishcrab
    Fishcrab Member
    152
    29
    Thanks to all, yea looks like there are a lot of approaches that these garages have. I like Patrick's doing it to the factory specks.
    Hopefully we can all have a long road to go.
    I'm surprised that I get in my car and it just goes at 150k
    Know that things can happen, but I just pat the car on the dash and say good car.
