Strange AC problem
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by john5396, Apr 13, 2015.
  1. john5396
    john5396 Junior Member
    Burlington, NC
    My daughter reported a strange problem with her Gen-II. Car is a 2007 with about 140K miles.
    She indicated that her AC is not cooling on the drivers side, vent is blowing hot air, but it is cooling on the passenger side, cool air from that vent.
    I told her to first check her cabin air filter, but I'm at a loss after that beside referring her to the dealer. Any suggestions?
    51,851
    my only wag is the vent not working properly on the drivers side, but i don't know if they are separate or one unit.
  3. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    What mode is the air control system in? Assuming the vents she's talking about are the ones near the doors, how about the other vents in the system? Do all the modes (floor, dash, combined, defrost) work properly? Does the fan work properly on all speeds? See if plenty of cold air comes out of the center dash or floor vents when those modes are selected.
    I'm pretty sure the side vents near the doors are not controlled from the MFD. They are always "on" and have to be controlled at the vent by the seat occupant.
    Turn the fan on high and see if there's a difference in the amount or velocity of air flow between the two side vents. Maybe a duct is broken?
    The passenger side vent is closer to the evap coil so if there's a problem or the system is marginal, any cool air might be felt there and it might not "make it" to the other side. That's just a wag, too.
  4. ITgem679
    ITgem679 Junior Member
    73
    17
    Does anyone know if this model has the capability to cool based on outside conditions? Climate control may be in play here?
  5. bisco
    51,851
    it probably has auto climate control, but i doubt it has separate controls for driver and passenger. but i've been wrong before.:)
    ITgem679 likes this.
  6. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    Most modern cars have heat all the time in the heater core but just divert the air around it when heat is not needed.
    Her symptoms sounds like one (or more) of the air director vanes is stuck in the wrong position.
    Putting it on cool, vent, heat and defrost and back a few times might help.
    If it is auto climate, then jack it all the way up for a minute and then all the way back down for a while.
    If none of that helps, it will probably require professional attention 'cause those deflectors and their "motors" are usually buried up behind the dash.
  7. Paul Schenck
    Paul Schenck Active Member
    523
    306
    Fresno, California
    That is a strange one. I was reading the Manual on the 2005 AC system last week. It's pretty cool the way it's engineered for efficiency. My wife was complaining she had no cold air and it turned out she didn't realize she had turned the vent off on her side? Well maybe I did it cleaning the car!
    iPhone ?
  8. bisco
    51,851
    that's it! how do you turn the vent off on the driver side only? shut down the grille in the middle, and the one on the left corner?
  9. Paul Schenck
    523
    306
    Fresno, California
    Left is off, right is open
    iPhone ?
  10. bisco
    51,851
    thanks. and the one left of the steering wheel, same thing?
  11. Paul Schenck
    523
    306
    Fresno, California
    All four of them.
    iPhone ?
  12. bisco
    51,851
    wow, that must have been some cleaning job.unfortunately, the o/p says his daughters vent is blowing hot air.:(
  13. JC91006
    JC91006 Senior Member
    16,764
    8,562
    The AC problem might just mean you have to recharge it. The cool air probably starts off in the passenger side and works itself to driver's side. If the system is weak, the driver's side would not cool properly. I would suspect the passenger side is not all that cool.
  14. bisco
    51,851
    good point, the fan starting behind the glove box.
  15. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    yep. must have a small leak. have it recharged and make sure they put a little uv dye in it. the uv dye is so bright green if there is a leak you don't usually need the uv light to find it unless the leak is extremely small.
  16. Easy Rider 2
    1,584
    258
    Ocala, FL
    You guys are overlooking one critical point:
    If the unit just was not cooling good enough, the air coming out of the drivers side vent should not feel HOT.......except right after starting up, that is. It should at least feel neutral.
  17. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Hope OP reports back w/ the cause. Man that's a lot of disassembly to get to the ventilation diverted thing Easy is talking about.
  18. Paul Schenck
    523
    306
    Fresno, California
    thinking about this has made mine go out? Blower blows, condenser condenses but temp of air is ambient??? Looks like I'm going deep into the dash!!!
    iPhone ?
  19. Patrick Wong
    18,200
    6,500
    More likely, the refrigerant level is low which would not require doing anything with the dash.
  20. Paul Schenck
    523
    306
    Fresno, California
    I thought that too Patrick though the condensate on the ground after a drive says other wise don't you think? I will check my fluid pressure before. Seems I was hearing the damper auto adjusting before and now I don't,
    Patrick have you ever had a damper get stuck perhaps due to a pencil getting dropped in a vent??
    iPhone ?
