The Killer Plugin 4th Gen Prius
Discussion in 'Gen 4 Prius Main Forum' started by inferno, Apr 17, 2015.
  1. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    51,844
    ooh, that's a lot to ask for.:p
  3. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Woah! Now you are talking oranges when we were talking apples before. Using "useable kWh" we have about 2.7 kWh. That's about 62 lbs per useable kWh. However, I'd say with investments in overall efficiency and better battery technology, we'll likely end up with 15 miles.
  4. bisco
    51,844
    i like it!(y)
  5. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Sergiospl likes this.
  6. bisco
    51,844
    seems to me, if 15 is doable in the current platform, it shouldn't be too hard to redesign for 20-25.
  7. Sergiospl
    3,938
    1,351
    28
    Really hope they can keep the functionality/utility of the current PIP.
  8. drash
    drash Senior Member
    2,576
    1,319
    Upstate NY
    Also remember, if SiC does make it into the Gen II PiP, it'll probably be a generation 1 SiC. As Toyota always does, they'll make them cheaper, lighter, and even more efficient in a second generation. The CT200h will then probably suck the Gen II SiC up, along with a refresh in the Gen IV.
  9. Sergiospl
    3,938
    1,351
    28
    Well, they said production of the 2017 PIP will begin October 2016.
  10. JC91006
    JC91006 Senior Member
    16,762
    8,562
    They need to make charging without cords. Park next to a tesla and steal their energy
  11. Trollbait
    12,505
    The Tesla will just drive itself to another parking spot.:p
  12. inferno
    inferno Senior Member
    1,072
    405
    Is there power share. Can I plug my pip into a tesla lol.
    Does anyone have an rv they plug themselves into ?
  13. Trollbait
    12,505
    But the conversion losses.:sick:
  14. inferno
    1,072
    405
    So traveling with RV towing a PiP doesn't make sense?
  15. Mendel Leisk
    41,332
    I'd just like to see a spare.
  16. Sergiospl
    3,938
    1,351
    28
    #36 Sergiospl, Apr 20, 2015
  17. Trollbait
    12,505
    No, charging the PPI off the RV doesn't make sense.
    A Tesla might be a better choice for the dinghy car, if its weight isn't an issue. It comes with an adapter to charge off of the 40 amp outlets at a RV camp ground.
  18. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    That depends partly on what percentage of your life you spend doing that.
    Charging a PiP with the RV generator doesn't make much sense but plugging it into the shore power outlet INSTEAD of the RV long enough to charge it probably does.
  19. Easy Rider 2
    1,584
    258
    Ocala, FL
    The common outlets provided at campgrounds are: 30A at 120 and 50A at 240. :)
  20. Trollbait
    12,505
    Right. I was confusing what the car would draw from the NEMA 14-50 outlet. The S comes with the adapter for that and the common 15amp house outlet. They also sell a NEMA 10-30 one.
    Tesla Charging | Tesla Motors
