Overtightened spark-plugs...what would you do?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Dale Earnhadrt, Apr 25, 2015.
  1. Dale Earnhadrt
    Dale Earnhadrt Junior Member
    chicago
    Watched a you tube video. Said torque on plugs was 20 ft/lb. That felt tight when I put them in. Further investigation says 150 In/lb or 12.5ft/lb.
    Should I take the new plugs out and toss them? I'm thinking if I go 100k miles with these plugs, they may be impossible to get out. I did use anti-sieze on the threads. Reason I'd toss them is because of the crush washer. Being crushed to 20#, I don't think they'd reaseal properly.
    Hope I didn't stretch the threads.
  2. JC91006
    JC91006 Senior Member
    16,659
    8,509
    How many miles are on your car now? How does the car drive? 7.5 ft/lbs more isn't all that much. I personally would leave it if the car is driving fine.
    Jon Hagen likes this.
  3. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Can you and are you willing to absorb the cost of replacing them?
    Because I'd say, if you want to? Do it.
    May or may not be necessary, but if you don't do it, you'll be worrying about it continually. For that reason alone I might say fix it now, and then enjoy it not being an issue. Even if it really isn't an issue now.
  4. A617
    A617 Member
    213
    95
    OKC, OK
    Leave it and drive it, 20 lb/ft is a lot when all you needs is hand snug and 1/8 to 1/4 of a turn to tighten, Undoing may damage the threads, it fine id just drive it and eventually sell it off when the time for new plugs are needed :) because fixing a stripped spark plug thread may require from re-tapping the threads to replacing the entire cylinder head.
  5. JC91006
    16,659
    8,509
    Many mechanics use air tools to put in spark plugs, 20ft lb is nothing. Just drive the car
  6. Mendel Leisk
    40,495
    Was that the Nutzaboutbolts video? I followed that, pulled them at around 40000 km, just to see how it was done, and to have a look. I THINK I used his torque recommendation. Can't remember exactly, but do remember thinking it was a little high, but oh well.
    Think you're fine. Hope I'm fine too, lol. Replacing them would be a lot of expense, and getting to them is crazy amount of labour too.
  7. bisco
    51,040
    i would replace them. peace of mind is everything.
  8. Former Member 68813
    3,524
    983
    US
    fix it ASAP. 20 lbs/ft with antisieze equals 30 lbs/ft dry. twice the normal. the problem is not damage to spark plugs but to the aluminum threads in the head!
  9. Dale Earnhadrt
    chicago
    Yep...it was the Nutzaboutbolts video. Good stuff other than the torque recommendation.
  10. Dale Earnhadrt
    chicago
    I have 117k on it right now. So the car would have 240 when I do them again.
  11. JC91006
    16,659
    8,509
    You may never have to change them again. Leave them
  12. ETC(SS)
    6,920
    Leave them.
  13. Dale Earnhadrt
    chicago
    I didn't know that but you are quite correct. Found this:
    http://www.antiseize.com/pdf/torque_specifications.pdf
  14. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Why would there be future damage ?
  15. Mendel Leisk
    40,495
    He's apparently an ex Toyota mechanic. What I take away is that a few extra pounds is not that critical. Next time I'll stick to spec tho.
  16. Dale Earnhadrt
    chicago
    I do not know. I am going to call my mechanic (he gets all the jobs I don't want to do) and see what he says. I can hear him laughing now.
  17. CR94
    CR94 Senior Member
    2,662
    1,150
    Northwestern S.C.
    Yeah. Luckily for everybody, for most ordinary bolted-together assemblies, there's wide latitude between so loose the thing falls apart or doesn't function, and so tight you break something. It seems only logical that specified torques should be somewhere safely mid-way between those extremes to allow for errors, variations in friction, etc. Obviously there are exceptions where hitting close to a specified torque (or bolt tension, to be more precise) truly is critical.
    Jon Hagen and Mendel Leisk like this.
  18. MikeDee
    MikeDee Senior Member
    1,572
    596
    San Francisco Bay Area
    Will you have the car that long? If not, don't worry about it. Every time you remove and replace plugs, you risk damaging the threads.
  19. frodoz737
    frodoz737 Top Wrench
    4,509
    2,430
    33
    Actually the service manual show the torque at 15 ft/lbs for the spark plugs (pg. 2936 ;)) and kudos for using anti-seize. "Technically" they are over torqued...but you should be OK on this one. Your call.
  20. Dale Earnhadrt
    chicago
    Pretty much what my mechanic said over the weekend when I called him. Leave them alone. He said I risk taking the threads with when I take them out.
    It is something I would disclose if I sold the car. It would not be right to do otherwise. This may not be a problem, however, as we tend to drive our vehicles until the doors fall off. Installing a helicoil insert isn't that big of a deal, anyway. Grease the tap so it catches most of the metal chips.
    The Electric Me likes this.
