Speed at which the Prius and Prius C have the same gas efficiency
Discussion in 'Prius c Technical Discussion' started by kalsifur, Sep 17, 2014.
  1. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    This weekend we'll have a real world test as my 2010 V-AT runs with a Prius c in the 21st Century Automotive Challenge around State College.
  2. Motov8r
    Motov8r Member
    102
    Worked for me. You also have to manage when you use the heater.
    iPhone ?
  3. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Yes blocking helps, but then you can block Gen3 and you loose again
  4. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    Cool. According to ANL, the plug-in gets better mileage than the both cars when cruising, although that's probably a lot closer if the 5 didn't have 17" wheels.
    http://avt.inel.gov/pdf/phev/fact2013toyotapriusphev.pdf
    Edit- NVM... It looks like the normal Prius gets about the same anyhoo...
    http://cdn2.hubspot.net/hub/195542/file-22765619-png/images/untitled.png?t=1422633189935
