Which one of you Toyota drivers is this?!?
Discussion in 'Fred's House of Pancakes' started by Eug, May 2, 2015.
  1. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    Parking fail.
    At first glance I thought it might be a Prius c, but I'm thinking now it's an Corolla hatchback (which I had never seen before).
    Toyota Corolla
    BTW, if that car had existed in Canada, we would have probably purchased that instead of the Yaris we have. No matter now though, since we are replacing it with a 2016 RAV4 hybrid.
  2. Mendel Leisk
    41,333
    Part of it is the bare minimum parking lot dimensions these days. Can you imagine it a bunch of full-size cars descended on it at the same time? Mmm, they'd probably all be cops, do fine.
    But yeah: combine tight quarters with someone not clear on steering wheel direction: perfect storm.
  3. Former Member 68813
    3,524
    983
    US
    the music was good.
  4. bisco
    51,844
    i'm frustrated just watching. turn the wheel the other way!!!:mad:
  5. bisco
    51,844
    corolla hatch? in the u.s.?
  6. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Corolla Auris!
  7. bisco
    51,844
    foreign?
  8. Sergiospl
    3,938
    1,351
    28
    Japan, UK, Europe, etc....
  9. bisco
    51,844
    thanks, i think it would be popular here, especially as a hybrid!
  10. fuzzy1
    10,409
    Not in the U.S., but at Werribee Plaza shopping centre, Werribee, Victoria, Australia. Note the right hand driver position, and video annotated with metric units, 24 hour clock, and non-U.S.-style date format.
  11. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    Yeah, when I did a search for Corolla hatchback and pic with that car's rear end, Toyota Australia popped up. I knew it wasn't Europe due to the shape of the licence plate, but as far as I knew it wasn't a North American car.
    BTW, off topic, but for some reason Australia won't be getting that Hybrid RAV4 we want. Luckily we in North America are getting it.
  12. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    About that date format.....it seems odd to me that we don't treat the date as a number, and write the digits in the proper numerical order. YYYY MM DD fits together perfectly with HH MM SS, just like numbers on an odometer. As if we were counting something....
  13. Trollbait
    12,506
    Some places do write it that way, or least the reverse; DD MM YYYY. There is an instrument or two at work that use that format.
  14. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Reverse is not an improvement. It's like mixing up the thousands, hundreds, and ones columns in a number, and then insisting it's OK, because, well...they're labelled. Or, because people should just know that's what the local convention is.
    Call me arrogant if you insist, but there's only one correct way to write the date.
  15. Mendel Leisk
    41,333
    YYYY MM DD has a number of advantages, not the least being that it sorts correctly in a text or file listing. The four digit year is both unmistakeable and alerts you to the sequence year/month/day. OTOH, if you have a date like:
    09 04 06
    good luck, lol.
    Off topic, if you want to know when your tires were made, there's a four digit number on the side wall: the first two digits are the week of the year, and the last two digits are the year. As an example:
    0509
    means the tires were manufactured in the 5th week of 2009.
    hyo silver and fuzzy1 like this.
  16. Trollbait
    12,506
    Some products, like pet food, will use the day of the year in a manufacture date.
  17. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    I live in Canada and I always write my dates as YYYY MM DD, unless it's a form that forces me to use a different format. With YYYY MM DD there is never any confusion, from anyone in any country, anywhere. That's the way they write the date in places like China, but even Americans will understand this.
    Too much confusion with DD MM YYYY or MM DD YYYY, and there is sometimes also confusion if you write the date as YY instead of YYYY.
    Damn Americans and their MM DD YYYY and imperial measurements. ;)
    GrumpyCabbie and hyo silver like this.
  18. Trollbait
    12,506
    If I recall, the Gimli Glider was a Canadian plane.
  19. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    On some dysfunctional level I kind of admire the driver for NOT giving up. Even as I watch the futility and say over and over...please god, give up before metal gets bent.
    I'd say the driver needs to think about getting a vehicle they can handle and would be easier to park. But THAT IS a smaller vehicle that should be easy to handle and park.
    So my recommendation would be always carry post it notes to leave on the vehicle you damage windshield, and keep your insurance paid up.
  20. hyo silver
    hyo silver Awaaaaay
    15,272
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    Yes, that 'glider incident' did happen in Canada. Over conversion confusion, so I'd say that's a point in favour of using one world wide standard system of measurement, not one against it. ;)
    More experience makes for more parking skills, right? No doubt that person is already a better driver...and likely an ashamed one, after they see the video. :)
