So what is your carbon footprint?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by cyclopathic, May 10, 2015.
  1. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    B/C EVs are using electricity?
    Wouldn't you wanna know if you'd better off charging your PiP or not from Carbon footprint point of view?
    51,843
    nahi would think the environmental forum would be more appropriate, since you don't have a pip, and some others commenting don't, and other ev's are being brought up.
    #22 bisco, May 13, 2015
  3. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    That's correct. However... Comparing the carbon intensity of electricity to the carbon emissions of a Prius isn't apples to apples since it's ignoring all the energy/carbon it took to discover/extract/transport/refine/and transport again the oil/gas conventional vehicles use.
    Gasoline and Oil
    Producing gasoline requires ~5-6kWh of electricity/natural gas that could be turned into electricity. So, right off the bat, just by not using gasoline, you've freed up enough electricity/natural gas to generate electricity to take most EVs ~20-24 miles. At that point, then you can look at the carbon required to take you the next ~26-30 miles, and compare that to the carbon a Prius emits driving 50 miles.
    Or... You can just add the carbon from producing the gallon of gas to the Prius tab and compare them that way, but you can't compare carbon intensity of electricity, which AFAIK includes everything needed to generate that electricity, to mpg, since that doesn't include the carbon released to make that gallon of gas.
  4. Eug
    Eug Swollen Member
    970
    223
    Earth (for now)
    Technology
    ^^^ I do not believe it takes 5-6 kWh of electricity to make 1 gallon of gasoline. That is based on misleading calculations. Remember, a barrel of oil doesn't just make gasoline. It makes gasoline and a whole bunch of other products. The energy use is to produce all those products.
  5. rxlawdude
    rxlawdude Active Member
    701
    219
    So Calif
    2015 Tesla Model S
    Hey bisco, can I suggest you quote at least part of the message you are responding to?
  6. bisco
    51,843
    of course you can!:p
    #26 bisco, May 14, 2015
    rxlawdude likes this.
  7. RRxing
    RRxing Senior Member
    2,545
    1,821
    NEPA
  8. hill
    8,794
    apparently you
    didn't read post #6 or its link ... but what the heck, our logic falls on deaf ears -
    really? . . . how many kWh's do you think it takes to run air craft carriers around the Persian Gulf to prevent the consequences of us being there in the 1st place .... or the kW's to run hospital's lung cancer/respiratory treatment centers needed due to fossil fuels / petrochemicals side effects, etc, etc. or do those kWh's not count against the usable remainder either ? .....
    #28 hill, May 14, 2015
  9. bisco
    51,843
    argh!!! you're right, i had no interest in the posts, just the forum. great minds think alike!(y)
  10. fuzzy1
    10,409
    In addition to old data, I also dislike the very large aggregation zones, so it is not really representative of the local area.
    My zip code produces the exact same results as all the test zips I entered across Washington, Oregon, Idaho, Montana, Utah, even parts of Nevada and Wyoming. And the results are vastly different than shown in my local utility's annual 'Fuel Mix' report.
  11. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    It's not strictly ~5-6kWh of electricity, it's some electricity plus some natural gas, which can be used for electricity. I think it's more natural gas than electricity, but the basic idea is that if you took the electricity used directly, and used the natural gas to generate electricity instead of using it as on site power for extraction and feedstock for refining, you'd get ~5-6kWh/gallon of gas.
    Fully Charged Discusses Electricity Use By Fossil Fuel Refining
  12. cyclopathic
    3,292
    547
    2014 Prius c
    I think 5-6 kW is over the board, if you look at well to wheel emissions on fueleconomy.gov it is less
  13. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    My wife and I are angels ;)
    Across all categories, we consume about 1/2 of the locals.
    I'd like to consume about 10%, but renting limits my options.
    I don't think that is quite right.
    Think of source energy: If you start with ~ 40 kWh of oil, after processing you end up with ~ 33.5 kWh of petrol
    #33 SageBrush, May 16, 2015
  14. roflwaffle
    roflwaffle Member
    381
    77
    Orange County
    The figures are from the state of CA in the early 2000s, so there might be variations depending on location, but it's more or less accurate. Refining efficiency is also part of the higher carbon footprint of oil, but a larger part is direct consumption of electricity and natural gas in extraction and refining (most as a feedstock).
    Very roughly, if we start with 40kWh of oil (1 gallon), we need an extra ~5-6kWh of electricity plus the electricity equivalent of natural gas (~55% conversion efficiency IIRC). That's why 25+% of the emissions associated with driving are from production of gasoline.
    http://www.transportation.anl.gov/pdfs/TA/273.pdf (page 3)
    Refinery efficiency is generally pretty high, usually at 90% or better, but all those additional natural gas and electricity inputs are why 25% of gasoline's emissions are associated with production.
    https://greet.es.anl.gov/files/hl9mw9i7
    Do you have a link to that? ANL lists 25+% of auto emissions as being from fuel production (in my last post).
    #34 roflwaffle, May 16, 2015
  15. cyclopathic
    3,292
    547
    2014 Prius c
    Go to fueleconomy.gov ran compare, select energy and environment and select tailpipe and upstream.
    For 2014 Prius C tailpipe is 178 and upstream 40g per mile. 40/218=18%.
    You could say that for every tailpipe CO2 lbs of emitted there is additional 22.4% upstream, but it is not 25%, and is not 22.4% of overall energy or emissions.
    Next the energy density of gasoline is 32.4 MJ/L, so this would amount to 7.7 MJ/L loss upstream, or 3.86kWh of electricity at 50% efficiency. Subtract 6% transmission losses, and you have 3.6kWh left. ~1/3 less than 5-6kWh you quote.
    3.6kWh is with very optimistic 50% efficiency assumption, the real life power plant efficiency is in 33-45% range, depending on fuel.
    I am not knocking on you but there's a tendency btw EV-nuts to rig the numbers in their favor.
    Amicus Plato, sed magis amica veritas
    #35 cyclopathic, May 17, 2015
  16. SageBrush
    11,627
    2,533
    Southwest Colorado
    Yep.
    This is why it is also a nice rule of thumb to say that of every ~ 40 kWh oil, 33.4 kWh make it into petrol. The conversion used to be 17% lost IIRC, but EPA has apparently bumped it up to 18%. Perhaps to account for shale oil ?
    #36 SageBrush, May 17, 2015
  17. cyclopathic
    3,292
    547
    2014 Prius c
    probably or perhaps to account for Canadian tar sands.
    BTW the energy content is down to 32.4 due to ethanol.
    Interesting that there is no statistics on electric plant efficiency, though it would not be hard to calculate it if you know how much stuff goes in and how much EV is going out. The peak efficiency of turbine is 60% but plants do not run at peak efficiency for most time and this does not include energy spent on fuel processing.
    And it would be interesting how electric plant efficiency will compare to HCCI when it arrives. Then the tables might just turn around.
  18. Zythryn
    Zythryn Senior Member
    6,408
    4,407
    "Electric plant efficiency..."
    Care to define "electric plant", I'm not sure what you are talking about.
    Electric motors??
  19. hill
    8,794
    I was thinking he meant something like in a hydro dam set of generators. Like in transmission loss to the end user.
  20. cyclopathic
    3,292
    547
    2014 Prius c
    What is the efficiency of different types of power plants? - FAQ - U.S. Energy Information Administration (EIA)
    there is more plant efficiency than just generator efficiency. For example nuclear and hydro whilst producing no carbon in generation, still have a sizable carbon footprint for different reasons. Hydro is a big methane producer, and nuclear due to ore processing. And any plant would have a footprint due to construction.
    Hydropower May Be Huge Source of Methane Emissions | Climate Central
    CO2 emission of electricity from nuclear power stations | Time for change
