Exhaust from other Cars Entering my Cabin (sigh)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by D53, May 18, 2015.
  1. D53
    D53 Junior Member
    27
    I have a 2010 Prius with 140,000 miles on it. This year, I am noticing that whenever I pull up behind a car in front of me which emits a lot of exhaust, the exhaust enters my cabin. I set the fan airflow switch to recirculation, but it doesn't seem to help. As best I recall, when I used to pull up behind a vehicle with bad breath, I would simply turn on the recirculation button and the problem would go away. Some time last year, however, I would turn on the recirculation button but it seemed as though it wasn't completely closing the vent and some of the bad breath would enter the cabin. Over time, more and more bad breath entered the cabin until it reached the point where it seemed that pushing the recirculation button did nothing whatsoever. The only relief was to turn off the fan completely.
    Right now, my car is at the dealership who is looking into this issue. However, they tell me that the vent thingie is opening and closing properly when the recirculation button is pushed. They suggest the problem is that the Prius is not a fully enclosed cabin, that air used to cool the high voltage battery gets into the cabin and, if I happen to be behind a stinky vehicle, then that is how the smelly exhaust enters my cabin.
    This doesn't make sense to me as pushing the recirculation button in the past always cut off the stinky exhaust.
    Any ideas as to what the problem is?
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    I notice this with the Prius.
    BUT unfortunately, I've noticed this with nearly every vehicle I've ever owned.
    It comes down to I think recirculate IS your best choice here, BUT also recirculate doesn't mean "Air Tight" ...some exhaust is going to reach the cabin regardless. The worse the offender ahead, the worse the offending exhaust smell.
    I don't find the Prius any better or worse in this regard.
    If it is extremely bad? I suppose you could have a vent or switch problem.
    PS.
    "Maybe" The Prius seems to vent in odors a little more than other vehicles. Because I'll say this, The Prius is one of the few vehicles I've owned where when I use the front windshield wiper wash? I can smell the fluid. I buy a fluid that has a nice smell precisely because of this.
  3. Former Member 68813
    3,524
    983
    US
    1. dont follow those stinkers too closely.
    2. the recirc is not 100%, more like 80% or such.
    3. you should be using the fan setting with filter icon, that 100% recirc but time limited, so you would not faint from lack of oxygen.
    i assume FL doesn't have the emission inspections like most civilized states and lots of people get away with removing the cat converters?
  4. xliderider
    xliderider Senior Member
    8,035
    3,211
    Honolulu, HI
    Cabin filters with activated charcoal are available for a modest cost.
    The OP hasn't mentioned how old the cabin filter is, though it probably was the first thing the dealer checked when investigating the reported problem.
    GrumpyCabbie likes this.
  5. ReDave
    ReDave Member
    82
    25
    Central California, Sierra/Sequoia Foothills
    2019 Prius Prime
    I have to agree with Electric Me. I feel that smelling exhaust happens too often [and specifically in my case diesels!] and what does seem to work, is the 'filter' button.
    yes the A/C then turns on, and of course i loose a little mileage, but the recirculate, and filter icon button... it seems to keep the cabin air cleaner.
    I also buy carbon filters from amazon that work and fit well, but i've felt that for exhaust, carbon isn't enough...
    good luck!
  6. The Electric Me
    9,083
    5,800
    Thanks, but I kind of flip flopped on my opinion.
    While I think every vehicle I have ever owned would let in exhaust fumes if I was behind them, after some thought I'd have to say perhaps The Prius is a little worse in this regard. Not horribly, but on a scale probably worse.
    The Prius IS the only vehicle I can remember where I can smell the windshield wiper fluid if I use it.
  7. Okinawa
    Okinawa Senior Member
    1,333
    317
    Try a charcoal cabin filter.
  8. ReDave
    ReDave Member
    82
    25
    2019 Prius Prime
    LOL now that you mention it, i do think i've smelled the WW fluid.
    My 'other' car [besides our priii] is a 1994 suburban i smell a LOT of stuff driving that thing!
  9. D53
    D53 Junior Member
    27
    Thanks all. The dealership also suggested using a carbon filter, however I do not think this will solve the problem. The dealership cannot explain why this problem has gradually become worse over time. The only thing I can think of is that, while it might look as though the vent flap thingie is functioning properly when closing,it must not be closing as tightly as it used to and that some adjustment should be made to it. But then again, I am only guessing...
    I am thinking about taking my car to another dealership for a second opinion.
  10. bisco
    51,040
    i suppose that that's a possibility. replacement might prove expensive.
  11. Mendel Leisk
    40,495
    What's sad: you're driving around in a nice clean car, and meanwhile some joker's singlehandedly dumping 100 or more times the crap into the air. Same goes for recycling, water conservation, it sucks. :(
    Yeah, we're the clean gang! :ROFLMAO:
  12. PriusInParadise
    180
    91
    Hawaii
    Just once, I saw something like what you describe. The air inlet servo had lost track of it's actual physical position and was not fully closing the air inlet door when the HVAC control recirc button was pushed.
    Suggest that the tech perform an active test of the air inlet servo.
    Using the Techstream, go to:
    Body Electrical / Air Conditioner / Active Test / Air Inlet Damper Targ Pulse
    Run the servo to min and max and visually verify that the recirc door fully opens and closes.
    Repeatedly cycling the servo using Techstream restored normal operation on the one car that I saw with this issue.
    xliderider likes this.
  13. D53
    D53 Junior Member
    27
    Thanks PriusinParadis! I will suggest that! As an added bounus, I'll actually sound like I know what I'm talking about!
  14. JC91006
    JC91006 Senior Member
    16,659
    8,509
    yes change the servo
  15. ChapmanF
    17,197
    Are you able to get a decent angle (maybe with the glove box doors out) where you could capture some video of the flap and/or servo moving and post it?
    I don't firsthand know the trick to pull heat/AC codes on a Gen 2, but if this post is right, it's just a matter of turning on the power while holding the brake and a couple buttons on the steering wheel. Any codes might help shed some light (I know my Gen 1 has codes allocated for servo problems, for example).
    I recently cleaned up the air mix servo on mine, it was quite easy.
    While I have no idea if this could be involved in your case, I remember seeing in the manual that the battery computer is empowered to command the heater from recirculate to fresh if it judges more battery airflow is needed.
    -Chap
  16. cjines
    cjines New Member
    San Diego
    I
    I'm having the same problem with a 2012 Prius. Had the Blend Door replaced at a cost of 1200 dollars but made no difference. Now I'm trying a charcoal filter. It's been very frustrating.
    Have you solved your problem? If so what was the issue?
    Thanks,
    CHuck
  17. bisco
    51,040
    do you have the filtration button on the '12?
  18. qdllc
    qdllc Senior Member
    1,371
    399
    This.
    I have allergies, and I've lived on RECIRC since spring. :eek: I don't need the FILTER button as often as I was using it when it was using outside air, but it doesn't block 100 percent.
    Also, by the time you can smell it, you're already too late. More is coming. You have to be more proactive to try and block it. You can use the Arm & Hammer brand of cabin air filter for better odor elimination and press the filter button (if you have it) as soon as you smell it.
    More so, I have to use Febreeze on the Prius every now and then for stuff that gets through and settles on the seat cushions.
  19. cjines
    cjines New Member
    San Diego
    I
    Yes
  20. bisco
    51,040
    i always slow down and let others get behind the stinkers. i like a good 10-20 car cushion. it's amazing how many people will pass you to get behind a school bus or construction truck, if you leave enough space.
