Slow acceleration
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jinxicheng, May 18, 2015.
  1. jinxicheng
    jinxicheng New Member
    Rotterdam
    Hello, my prius 2010 (III) accelerate much slower than before. I started noticing this after I picking up my car from the airport. Parked the car there for a week. I have the dealer checked the computer but no error codes found. My car has almost 250k KM on it. I have not replaced the spark plugs the last three years. Could it be the spark plugs?
  2. JC91006
    JC91006 Senior Member
    16,724
    8,546
    Your car is 5 years old, not 3 years old. Ever replaced the spark plugs before?
    If the spark plugs are original, then I suggest you replace them. You should also clean the throttle body and MAF sensor while you're at it.
    Your acceleration issue might be related to low battery SOC and possibly dirty air filters.
  3. bisco
    51,501
    nothing good ever happens at the airport.
  4. Mendel Leisk
    40,939
    Maybe plugs were replaced 3 years back?
  5. bisco
    51,501
    plugs are at 120k, did you drive that much?
  6. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    In europe, spark plugs are every 90.000 km.
