Will other '08 xB sway bars fit the Prius?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by burstaneurysm, Apr 22, 2013.
  1. burstaneurysm
    burstaneurysm Active Member
    469
    144
    Chicago, IL
    I know the TRD swaybar for the '08 xB is essentially identical to the TRD Prius bar, but has anyone successfully used a different bar for the xB?
    A guy on my Scion forum is selling the Hotchkis front and rear bars for the xB.
    I wonder if they'd fit.
    In the same vain, are the front bars compatible too?
  2. peterjmc
    917
    189
    Clarksburg, MD
    I have the '08 xB Hotchkis bar set (Front and Rear) sitting in my trunk right now :)
    There is a thread on here where a forum member did confirm that front and rear do indeed fit. I haven't come across any other manufactures which produce a set other thank Hotchkis for the '08 xB.
  3. Rixmixx
    Rixmixx Junior Member
    Did the front bar fit well and if so, how was the handling after the installation?
  4. xliderider
    xliderider Senior Member
    8,041
    3,214
    Honolulu, HI
    There's a thread here about the RAV4 Sport front sway bar (1mm thicker than stock) fitting the Gen 3. Not sure about the model years though.
