HELP PROBLEMS WITH 2006 PRIUS
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Allyson Likes, Jun 1, 2015.
  1. Allyson Likes
    Allyson Likes New Member
    Reno
    today on my way to work after getting gas at the normal gas station i always do, i was leaving and the red warning light with the "!" in the middle came on as well as the check engine light and another one. My car was still driving the same and felt ok so i just drove my 2 miles to work and called my parents. But can anyone help me with this problem or maybe know what could be wrong ??????
    My 2006 prius has 109k miles
  2. JC91006
    JC91006 Senior Member
    16,764
    8,562
    Check to make sure you are not low on oil. Did you do the recall on the electric water pump?
  3. Allyson Likes
    Reno
    i didnt know there was a recall !! now lets hope that's all thats wrong with it lol !! THANK YOU !!
  4. JC91006
    16,764
    8,562
    Call your local toyota dealer service dept, provide them with your car's vin number....then ask if there are any open recalls.
  5. kutcht1
    kutcht1 Member
    305
    82
    Andover, Minnesota
    For the inverter/ATX pump just take off the coolant cap and check to see if there is any fluid movement. This will tell you if that pump is running.
    TomK
  6. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    check engine light will come on if you leave the gas cap loose. make sure its good and tight.
