Brake pads make a cracking noise over bumps.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DGH, Jun 8, 2015.
  1. DGH
    DGH Thread Terminator
    365
    93
    Wales, WI
    Anyone else have their brake pads making noise while driving on war zone like roads?
    Sounds like the front end is falling off.
    It started after a front brake job. Dealer then replaced all the clips and it was fine for six months.
    Now starting to make noise again.
    Thanks,
    Dan
  2. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Mine has always done that.
    It's harmless.
    I live with it.
    DGH likes this.
  3. DGH
    365
    93
    Wales, WI
    Thanks for your reply.
    Yeah I realize it's harmless but I guess I have a low tolerance for extraneous noise. I wonder why after 200k of nice quiet performance this is going on. I find it very annoying and embarrassing getting those "what the hell is that" looks from people. Yes I also have the quietest bicycle on the road, there is no other way for me.
    Thanks,
    Dan
  4. valde3
    valde3 Senior Member
    2,002
    749
    Finland
    It could be fixed. Probably it is the brake backing plate. And fixing that or many other possible faults would only take time.
    DGH likes this.
  5. DGH
    365
    93
    Wales, WI
    Can I ask for a little more detail on the backing plate? Is that the same as a shim? If so I'm told Toyota no longer has shims.
    Thanks much,
    Dan
  6. valde3
    2,002
    749
    Finland
  7. DGH
    365
    93
    Wales, WI
    If you brake over the bad road surface you do not get the noise. I believe that's why the dealer says it's the clips holding the pads in place.
    What I don't get is why all was fine until 200k and new front brakes.
    Thanks,
    Dan
    #7 DGH, Jun 8, 2015
