Brake disc wear
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Lutchenko, Jun 9, 2015.
  1. Lutchenko
    Lutchenko Will Perrin
    307
    211
    Milton Keynes England
    So after measuring I get offside 23.8mm and nearside 23.7mm
    So if the unworn thickness is 25mm and the lower limit is 22mm I make that 40% and 43% wear respectively.
    I can feel a communication with the dealer coming on
    51,040
    well done.(y) are they scored or anything? how are the pads?
  3. Lutchenko
    307
    211
    No scoring. I was able to measure through the spokes so haven't been able to assess the pads yet
  4. ChapmanF
    17,199
    40 to 43% still seems an awful lot of wear for 58,000 miles. Mine seemed to be down by about 65% at 210,000 miles, after machining ... and I turned out to have some sticky caliper conditions speeding up the wear. So it's probably worth taking things apart to make sure they all move nicely.
    How about runout - spinning the rotors by hand with a dial indicator resting on the surface near the rim, do they measure flat and straight?
    -Chap
  5. frodoz737
    frodoz737 Top Wrench
    4,509
    2,430
    33
    Brakes are brakes. While the Prius has shown less wear and less problems than most, they still require maintenance and monitoring. The ONLY other car I have ever owned that has had the same or less problems with brakes is my 2006 TDI Beetle...although the this specific vehicle has had many other maintenance nightmares.
  6. Mendel Leisk
    40,495
    Maybe OP's discs have been turned?
  7. bisco
    51,040
    without his knowledge?
  8. Mendel Leisk
    40,495
    Might be embedded in a brake job invoice? Some dealerships are pretty trigger happy, machining rotors routinely. I think part of it is their need for fast, quantifiable results.
    The other side of the coin: my rear rotors were pretty knackered, due to misalignment between pad and piston I think. The rotors were scored, and inside faces had a lot of rust.
    I put in new pads, was careful with aligning and seating them. And it sounded like crap for a week or two: it took a while for everything to get back into equilibrium.
    It did, the rotors look great now, but it took a while. But maybe a dealership doesn't want to go this route: they just machine them, no phone calls.
    #28 Mendel Leisk, Jun 10, 2015
  9. Lutchenko
    307
    211
    The discs haven't been turned. They still measure 25mm across the non contact area.
    I live in a town with around 300 roundabouts so we do see high tyre wear and I guess brake wear from the constant stop start.
    However majority of my mileage is motorways and I average 52mpg overall.
    My main concern now is why I'm being advised to undergo an expensive maintenance on a component that is not even 50% worn.
    I have submitted an enquiry to the dealer and await their response
    #29 Lutchenko, Jun 11, 2015
  10. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    Never trust a dealer, ever.
  11. Lutchenko
    307
    211
    Here is their response...
    Good Morning Mr Perrin,
    Regarding your enquiry this morning, I have your Visual Safety Report to hand from your recent visit. My technician has reported your brake pads as approximately 80% worn and discs worn. The minimum thickness allowed for the disc is 22mm and from new will be 24mm. Unfortunately I don’t know what the exact measurement of your discs are now but we have a duty of care to report any items classed as amber or red which are highlighted on the VSR. We will advise any brake work to be done at 75% wear and above hence why we have reported the brakes to you. The concern is more to do with the pads rather than the discs and obviously we would not recommend new pads on old discs depending on how worn they are. Looking at the history of the vehicle and its current mileage, it looks as though you’ll be back in around 5-6 months. At this time we will be able to re-measure the pad and discs wear for you as I’m sure they will be perfectly fine until then.
    Hopefully this has answered your concern Mr Perrin but if you need any further assistance please contact me on the number below.
    Kind Regards
  12. bisco
    51,040
    sounds reasonable. i don't think i could get a written resonse like that from any dealer i've ever been to. i guess you'll have to have a look at the pads.
  13. Lutchenko
    307
    211
    Yes I agree but I'm still not happy to change the discs as well as the pads even if the pads are low.
    Personally I think I'd opt to replace the pads alone but that's just me.
  14. Mendel Leisk
    40,495
    You hear a lot of talk about replacing rotors with new pads. I've never subscribed to that, just replaced pads, over the years. Works out fine every time.
    I've only once had rotors get down to minimum thickness, and in that case the car seemed to be "eating" pads, every 30k km's or so, pads not releasing properly, for reason I never resolved. Sticking piston? Anyway, one disc finally cracked.
    The car felt like it had a broken back every time you stepped on the brakes. I checked the discs and found the crack. Brought it in, reporting that I'd seen a crack. They called back half hour or so later, saying it was all fine, and no crack. I told them to check again, and then they found it. It was at that point I lost all faith in that dealership.
    They had a very good service manager at the time, very knowledgable, helpful showing you the options when there were repairs needed. Anyway, we talked on the phone that day, he acknowledged they'd completely dropped the ball on the cracked rotor.
    He didn't last long there though: I heard he's teaching in a local community college now, a better fit. :)
    #34 Mendel Leisk, Jun 11, 2015
    Lutchenko likes this.
  15. bisco
    51,040
    agreed, there must be a spec on when discs need smoothing or replacing, but i would just eyeball it. from the dealers point of view, it's the perfect scenario. he takes no chances, presents you with brand new brakes so to speak, with less chance of problems, and makes money in the process.
  16. ETC(SS)
    6,921
    Pardon the sidebar question, but wouldn't rotaries (you call them roundabouts) make for less rather than more brake and tire wear???
    Americans are rather poor drivers.
    We have trouble even with binary intersections, let alone something that actually requires one to put down the phone and drive......but I always thought that rotaries would make for fewer stops and with a little forethought, better mileage and smoother traffic flow.
    I still think that something is amiss.....unless you deliver the post or are in practice for a for an upcoming Formula-1 race.
    Sorry,
    I'm not seeing a 3-year old, 60,000 mile, adult-driven Prius as a candidate for new brakes.
  17. Lutchenko
    307
    211
    One of the problems with roundabouts here is that people tend to go around them at speed and of course the nearside tyres tend to take quite a pounding. It's common problem that we see in my town.
    As far as brakes are concerned the other issue we have is that people tend to arrive at the roundabouts with enough pace to slide in to a gap that they have been timing their approach for and of course quite often things change and you end up on the brakes fairly hard in order to abort your manoeuvre. But I think your observation that roundabouts could potentially reduce brake wear could be valid if people didn't drive around with their hair on fire lol
    Years ago I used to drive this way, BMW :) , but since owning a Prius I certainly drive more carefully and am very mindful about hard braking.
  18. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    From the 2010 Repair Manual:
    Brake Pads
    New - 10mm
    Minimum - 1 mm
    Discs
    New - 25mm
    Minimum - 22mm
    The manual says to measure the pads with a ruler, the discs with a micrometer. A "Visual Safety Report" is just that.
    Get a second opinion and have them let you watch when they measure.
  19. Mendel Leisk
    40,495
    If either of the above measurements are nearing the lower limit I would replace sooner than later. Especially the pads: if I open up a caliper to find pads at say 3mm, I'd leave it open, make a verification phone call and walk to the dealership ( blessedly nearby), for new pads. And likely replace the shims as well. The end clips seem to last forever, maybe stainless?
  20. frodoz737
    4,509
    2,430
    33
    Assuming the rotors are in spec and not gouged or heavily grooved, you can just change the pads. Some recommend ""lightly"" scuffing or sanding them to cut the glaze or rust before installation, but either way you will be just fine. It's a good idea if you do this to hit an empty parking lot to bed or cut pads in though. This also gives you a good excuse/opportunity to flush the brake fluid ;) while your at it.
