Super simple DIY navigation visor
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Ovals49, Jun 5, 2013.
  1. SkookumPete
    SkookumPete New Member
    Vancouver Island
    This is great info. I just made one and it took about 15 minutes. I sanded a slight curve to accommodate the shape of the dashboard.
    No way I was paying $35 plus shipping to Canada for the plastic visor sold here.
  2. Markee
    Markee Member
    333
    South Florida Broward County
    What size screen do you have will this work with my 6/1" screen ?
  3. Markee
    Markee Member
    333
    I just got one of these
    What did you use to hold it on the dash ?
    #23 Markee, Jul 1, 2015
  4. cheizy
    cheizy Member
    94
    129
    Los Angeles
    Hey @Markee
    I used velcro to stick it to the dash initially so I could remove it easily. However after a hot summer, I removed this mod. Reason for was because the velcro would get so hot after parked in the sun the glue would start to smudge and eventually the visor would just fall.
    Good visor mod, but need a better attachment method.
  5. kalamesa
    kalamesa New Member
    91942 so cal
    What material did u use ? How does it stay in cd drive slot ?
    Thanks
    KA
    It does a decent job of keeping direct sunlight off the screen from all but the lowest angles, even without "wings". My scrap piece happened to be charcoal / maroon so I didn't even need to color it to blend in nicely with the dash materials.
    Hey, it's nothing fancy, but it does the job and you can't hardly beat the price![/QUOTE]
  6. DoubleDAZ
    DoubleDAZ Senior Member
    1,209
    322
    Peoria AZ (Phoenix)
    I recently redesigned mine. I cut some pieces of cardboard to the shape of the CD slot and sandwiched 2 together for a snug fit. I then added a full length top to it that molds to the section above the slot and radio dials. Probably not a big concern, but I used cardboard rather than plastic to lessen the danger in an accident. Since it works, when we get home from vacation, I think I'll get some foam from Hobby Lobby or somewhere for a better appearance.
