2008 155,000 Mile Maintenance
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jake Joseph, Jun 19, 2015.
  1. Jake Joseph
    Jake Joseph Junior Member
    28
    Tampa, FL
    Hello All,
    This is my first time here posing on Prius Chat so I thank any and all help!
    I bought a 2008 Prius in White Loaded back in December of 2014 with 146,000 miles and its been nothing but a pleasure to own! I now have 155,700 miles on it and have a service appoint scheduled for tomorrow.
    I'm about to have my second service done tomorrow and wanted to ask what service is necessary for my vehicle. I know that I should probably have the ATF changed because according to the service records its never been done. Another concern that I have is some other services that the previous owner had done that i don't know if i should have done too. I have written up a word document of my concerns and will copy and paste it below. And if there is a service not listed below please feel free to add it and if you have an estimate on price that would be awesome too!!! I plan to have the servicing done at the dealership, but plan to negotiate as i always to :). I also don't know what my brake situation is, i was told at my last service that they had 50% pad life left and that they were the original brakes.
    Thank you so much for your help!!!!
    2008 Toyota Prius Maintenance
    Performed Maintenance
    · 138,011 Drive Belt
    · 121,527 Brake Fluid Exchange
    · 115,918 Spark Plugs and Serpentine Belt
    · 99,631 Water Pump
    · 87,879 Injector Cleaning
    Oil Changes always done at the 5,000 mile interval and sometimes sooner.
    Concerns:
    · Oil and Filter Change
    · Brake system inspection (Rotors, Drums, Pads, Shoes, Fluid, and Calipers)
    · ATF Fluid Condition/Change?
    · Vehicle Inspection (Any Other Maintenance Items/Concerns) 155,000 Miles
    · Fluid Top Off
    · Recalls?
    · Induction Service?
    · A/C Evap Clean?
    · Top Engine Cleaning Kit?
    · Cabin Air filter and Engine Air Filter change not necessary (Done Myself)
  2. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    oil and filter yes
    brake inspection yes, but it most likely won't need anything unless someone drove the car wrong. pads and shoes usually go 180k+
    4 qts genuine Toyota WS atf definitely
    vehicle inspection should be free at any shop, when they find a problem that's how they make money.
    fluid top off yes diy
    recalls yes
    induction service, if you noticed any crud around the throttle valve when you changed the air filter, you should clean that out with a lint free cloth sprayed with throttle body cleaner. don't just hose the throttle valve down with the cleaner even though that's what it says on the can, spray the cloth and wipe the gunk off the throttle valve and the bore.
    a/c evap clean, only if it stinks. otherwise just spray fridge-fresh or something like that into the cabin filter opening with the blower on.
    top engine clean? not likely to need that.
  3. Jake Joseph
    28
    Tampa, FL
    Thank you very much for your guidance and help!
  4. Patrick Wong
    18,200
    6,498
    What is the difference between a drive belt and a serpentine belt? They are one and the same.
    I suggest you have the PCV valve replaced now since that did not appear on either of your lists.
    Which "water pump" are you referring to? If you are not referring to the engine coolant pump, that should be inspected for coolant weeping at the bearing weep hole, and replaced if the weeping is more than trivial.
    The inverter and engine coolants are supposed to be replaced at 120K miles so since that did not show up on your list, that should be done now.
  5. Jake Joseph
    28
    Tampa, FL
    Thank you for your help! I just found in the records the PCV was done at 93,000 miles and i do not know which water pump was replaced its just listed as a water pump on Toyota Owners and CarFax. Do you know the estimate for the two coolant changes?
    Thank you!
  6. Jake Joseph
    28
    Tampa, FL
    Also at 93,000 miles and now at 156,700 Miles do you think the PCV valve should be changed again?
  7. Jake Joseph
    28
    Tampa, FL
    I also just referenced the carfax and the water pump replacement is listed twice possibly the engine pump and the other water pump (dont know name sorry) have been replaced.
  8. Jake Joseph
    28
    Tampa, FL
    Here is the revised list.... any comments/concerns?
    · 110,262 Water Pump Replaced
    · 99,631 Water Pump
    · 93,125 PCV Valve
    Concerns:
    · ATF Fluid Change
    · Fluid Top Off
    · Inverter Coolant Exchange
    · Engine Coolant Exchange
    · PCV Valve Change
    · Recalls
    · Induction Service
    · A/C System Service/Check
    · Injector Flush/Service
  9. Patrick Wong
    18,200
    6,498
    No, it should be good easily for 100K miles.
    I would skip the injector service unless you have an engine problem that the service might help.
