Repairing car tire
Discussion in 'Newbie Forum' started by primuspaul, Jun 20, 2015.
  1. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    What do you guys use to repair car tires that are off the rim (from the inside)? Can I use some kind of adhesive, like silicone?
  2. JC91006
    JC91006 Senior Member
    16,669
    8,516
    Or you can bring it to a tire shop that does free repairs
  3. xliderider
    xliderider Senior Member
    8,041
    3,214
    Honolulu, HI
    Plug and patch from the inside is the industry standard.
  4. Okinawa
    Okinawa Senior Member
    1,333
    317
    Take it to a tire shop and have them fix it.
  5. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    I will try to see if a shop will do it. But failing that, will this work?
    I assume it does not need a separate application of vulcanizing paste. Correct?
  6. xliderider
    8,041
    3,214
    Honolulu, HI
    This one has better reviews:
    And I'd still use the rubber cement with it. It will make inserting the plug easier, and it will make a better seal.
  7. Mendel Leisk
    40,516
    I've used a plug repair a couple of times now, once on the OEM, once on the snows. Worked fine, has held up. I splurged and got the black jack kit, around $50.
    Kt-340 - BlackJack Tire Repair
    #7 Mendel Leisk, Jun 20, 2015
  8. frodoz737
    frodoz737 Top Wrench
    4,509
    2,430
    33
    Not trying to sound crass but if the tire is off the rim already, a tire shop or someone with proper tooling had to take it off for you. Is the area needing repair out of limits...like too close to the sidewall or something else?
  9. Okinawa
    1,333
    317
    Right. Plug and patch from the inside is the industry standard. Not just a DIY plug. Those are not considered to be safe.
  10. Mendel Leisk
    40,516
    I'm not advocating for others, but:
    One of our OEM tires had a finishing nail, say a thumb's width from corner of tread. The dealership wouldn't touch it, said it was too close. I opted to do an old-school plug repair, that was maybe two years back
    About a year later picked up a small bolt in one snow tire, about the same distance from tread edge. Didn't bother asking, knew the answer, plug repaired it. It's fine too.
    Maybe risky, I know, but they seem very solid.
  11. bisco
    51,066
    whats life without a little risk?:p
  12. Mendel Leisk
    40,516
    A lot more expensive. :(
  13. primuspaul
    primuspaul Member
    244
    NYC Area
    2002 Prius
    I
    It is a fairly old tire and that spot has been repaired twice already. Started leaking again so I figured may as well replace it. My interest in it is keeping it as a backup tire.
    Now if only I can find a rim to mount it on...
