dumb question #47 (those battery cover clips)
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by cutter44, Jun 20, 2015.
  1. cutter44
    cutter44 Member
    213
    MA
    It was a nice day today, so I figured I ought to explore my C a bit in the event I ever need to jump start the 12v battery. What a pain in the butt. I hope I never have to do this in the middle of winter. I envy the owners of a regular Prius who apparently have easier access to jumping points under the hood.
    In any event, I managed to remove the clips, remove the cover and see the horrible inconvenience of it all. But worse, I must have spent more than a half hour trying to get those two clips back in the holes. One of them went in properly, but the other one still isn't in quite right. Those ends that spread out to keep the clip in (once it's in) have a way of spreading a bit too far apart on the way in, so it's nearly impossible to get in that hole. And yes, I even took the pin part completely out to see if it helped. It didn't.
    Is there some trick to getting them back in? Thanks.
    [/rant]
    51,023
    are you sure there isn't a jump point under the hood?
  3. cutter44
    cutter44 Member
    213
    MA
    Funny you mention that. I just found a YouTube video that shows such a jump point on a C. I don't know what model year it is in the video or whether mine has it, but I'll check it out tomorrow (weather permitting). Here's that link:
  4. Mendel Leisk
    40,461
    The early Prius c didn't have under hood battery jump point I think.
  5. kevtan
    kevtan Member
    Early 2012-2013 don't have jumpstart at hood .
    iPhone ?
  6. cutter44
    cutter44 Member
    213
    MA
    Yep. Bummer. Sure would be convenient. Wonder if they could retro-fit. :)
  7. bisco
    51,023
    wow, that's kinda shocking, especially considering the battery location.
  8. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    I had to have a jump after an idiotic move a couple of years ago. Luckily, it was while Toyota Care was still active. Sure enough, the seat had to be removed to access it. I guess the impracticality of that oversight made them correct it not long after debut.
  9. bisco
    51,023
    amazing, the simple mistakes engineers can make sometimes.
  10. Mendel Leisk
    40,461
    There was a lady with an early Prius c, lamenting about the nonsense involved getting at the battery for a jump start, by the side of road, dark. Maybe 6 months back.
    Mechanical access seems to really take a back seat these days. Oh woops, a Prius c pun.
    Motov8r likes this.
  11. bisco
    51,023
    at some point in the design process, the under hood jump point was either forgotten, overlooked, or cut out by the bean counters.
  12. vinnie97
    1,430
    277
    Somewhere out there
    And it just dawned on me that if I add an EV as a supplement to this vehicle in a few years, it will make maintaining the battery on it all the more impractical...
  13. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    I'm glad I bought the 2013. But, an oversight like that is astonishing ! What morons. So for my future access, I may want to just take the rear seat out.
    Does anybody know if it just pulls up from the front edge, like the PIP ?
  14. cutter44
    cutter44 Member
    213
    MA
    Well, supposedly, jumping the battery without removing the seat is possible, but I'm hoping I never have to find out.
  15. bisco
    51,023
    i would go through the motions, before i had to do it for real, on a dark rainy night in the middle of nowhere.
  16. cutter44
    cutter44 Member
    213
    MA
    I'm hoping AAA will know how. :)
    Or come to think of it, I bought the Toyota Platinum Extended Warranty which has 24/7 Roadside Assistance, so if I ever need to, I'll let them deal with it.
  17. Mendel Leisk
    40,461
    Yes, and take some pics, and post how it went. Good for other owners to know.
