Squeak on driver's door panel
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by 4rpr15, Jul 25, 2015.
  1. 4rpr15
    4rpr15 Senior Member
    1,056
    375
    WI
    I guess it's more of an annoyance thing than anything else. When I drive I like to rest my knee on the this area where the window switch is. If I drive over a bump etc...this area squeaks. Is it worth having the dealer fix or will it just return. If anyone with the same issue can chime in I would appreciate it.
    The door piece where the window switch is tends to squeak when I rest my knee on it. Driving over bumps, etc....any quick fix...other than not resting my knee on it.
    #1 4rpr15, Jul 25, 2015
    51,840
    if you don't rest your knee on it, it doesn't squeak?
    does it only happen when your knee is resting on it?
    the door panel is easy to take off, you probably just need some wd40 in there.
    #2 bisco, Jul 25, 2015
  3. JC91006
    JC91006 Senior Member
    16,761
    8,562
    Bring it to the dealer and let them sort it out under warranty
  4. 4rpr15
    1,056
    375
    WI
    That a given, but I was wondering if anyone has the same issue and if they fixed it themselves.
    It's just more annoying than anything.
    Yes that's the only time I hear it which means when weight is applied hats what forces the squeak to be heard. Otherwise it's fine.
    That is correct.
    #4 4rpr15, Jul 26, 2015
  5. bisco
    51,840
    it must press the door panel against something inside. perhaps a bit of foam between the surfaces.
  6. JTM2955
    JTM2955 Active Member
    475
    185
    Hmm. Can you remove the window switch, then drive it and see if it still makes the noise.
    Isolate the noise, this will also help the technician to fix your car. That is if you can find the cause of said noise.
    Mine has a noise at the middle speaker. I put tape beneath the speaker and no more noise.
    LG-D851 ?
  7. JC91006
    16,761
    8,562
    If there's a squeak, just bring the car to the dealer and get yourself a free donut and car wash. let them figure it out, that's why you have a new car with a warranty
    JTM2955 likes this.
  8. bisco
    51,840
    i like to tell them how to fix it when i bring it in, they appreciate it.
    JTM2955 likes this.
  9. JTM2955
    475
    185
    Yes, it really does help the tech to steer them in the right direction. Take a ride with the tech and replicate the noise. Otherwise, you'll get the car back with "unable to duplicate".
    It happens sometimes when people have repairs done by non dealership people. Then they go running back to the dealer saying My car has this problem, and it just happened. Yeah right.
    LG-D851 ?
