Cabin Air Filter cover
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jack520, Jul 27, 2015.
  1. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    When I replaced the cabin air filter recently, I noticed the little latch loop on the left hand side bottom was broken. I just put it together and it does not rattle.
    Anyone have this problem ? What did you do to address?
    It looks like a major repair to replace to part.
    Thanks Jack
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    If it's under warranty I would try to get it replaced. If not, I'd ignore it.
  3. bisco
    51,844
    someone else put a dab of duck tape on it. very fragile in there.
    more important than rattling is the seal. you can test it by turning the fan on high with the glovebox out. switch through the fresh/recirq a few times as well.
