Is there supposed to be a fuel flap?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Grayson73, Jul 31, 2015.
  1. Grayson73
    Grayson73 Junior Member
    62
    Maryland
    My check engine light has been coming on and I've been re-tightening the gas cap; sometimes it works and sometimes it doesn't.
    I noticed that when I look at the hole, there is no flap to block the hole. Is there supposed to be a flap that blocks the hole until you insert the gas nozzle when filling gas?
    51,843
  3. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Inside of the cap blocks the hole!
  4. bisco
    51,843
    might need a new cap?
  5. Grayson73
    62
    Maryland
    Possibly. How does a cap break?!?
  6. Sergiospl
    3,938
    1,351
    28
  7. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    This is no answer, but I know what you mean.
    I live in Oregon where gas is not self serve.
    But my Honda Fit had a gas "flap" just inside the opening after removing the cap. It was spring loaded. I know this because of times I added a treatment of Techron to the tank. I had to be sure to push the "nozzle" of the bottle past the spring loaded flap.
    I've ran a treatment or two of techron through the Prius but for the life of me, can't remember if a similar flap exists.
    I'd just make a quick stop at the dealership, because you either need a new flap...or a new gas cap. So either way the trip wouldn't be waste.
    Edit: Just saw above posted picture. So I guess you need a new gas cap.
  8. RRxing
    RRxing Senior Member
    2,545
    1,821
    NEPA
    No flap on Gen III.
  9. bisco
    51,843
    if it is broken, i can only think there is some type of rubber seal.
  10. Melchior
    Melchior Junior Member
    74
    Netherlands
    Mine has no flap. It surprised me when I first filled up because all the other fuel injected cars I've ever owned have had a flap. Only owned one carb'd car, have had a few diesels and none of them had a flap; assumed it was a vapour emissions thing. I much prefer it without one, means you can really properly brim it.
  11. bisco
    51,843
    you can't brim it here, because we got the blatter.
  12. Patrick Wong
    18,200
    6,500
    No.
    Check the condition of the O-ring which seals the fuel cap.
