Jack spots on a 2014 Prius c
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by ovillarr13, Aug 15, 2015.
  1. ovillarr13
    ovillarr13 New Member
    Pasadena, CA
    2014 Prius c
    Hello everyone, I'm new to this community, and car, and I was just wondering if anyone knew where the jack spots for the 2014 Prius C were.
    I know where the side ones are [​IMG]
    But I was wondering if anyone knew where the rear jack spot was.
    I'm assuming it's the that blue piece sticking out between the black and the grey (sorry for the lingo, not a car guy) but I just want to make sure that's the spot I can put my jack.
    Thanks in advance.
    iPad ?
  2. xliderider
    xliderider Senior Member
    8,041
    3,213
    Honolulu, HI
    Check your owner's manual. ;)
    There's usually a front and rear jacking point for floor jacks as well.
  3. Mendel Leisk
    40,515
    Think you've got it right. Page 366:
    FWIW, I don't like putting safety stands at Toyota's scissor jack locations, they're so flimsy. Usually if you look around you can find something more solid in the vicinity.
  4. ovillarr13
    Pasadena, CA
    2014 Prius c
    I had looked at the owners Manual, just wasn't too sure. You guys put my mind at ease. Thanks.
    iPhone ?
  5. xliderider
    8,041
    3,213
    Honolulu, HI
  6. FireFire
    FireFire Junior Member
    99
    Ontario, Canada
    That looks good. Pricy... I will bite under $10.
    The front jack location is pain in your xxx. I can't even send my jack to that location, very very far back from the front. Last time I have to jack it from the side to do oil change. I think I will make a ramp for her.
  7. Mendel Leisk
    40,515
    Get something like a 3 ton jack, more reach.
  8. FireFire
    99
    Ontario, Canada
    3 Ton is too thick to get under the body. Unless you get those low profile. No idea why Toyota designed like that.
  9. Mendel Leisk
    40,515
    Tell that to my very regular 3 ton. :ROFLMAO:
    And even if it doesn't fit, drive the front tires up onto short sections of 2x8, there's always a way. :)
    #9 Mendel Leisk, Aug 19, 2015
  10. FireFire
    99
    Ontario, Canada
    You have a C? The front bumper doesn't look like any version of C.
    Yes. I do agree to drive on a short ramp is the better way. Not sure about Prius, but the front jackup location seems diff than C and regular prius.
    Take a look at My Super White Prius c One (with various undercarriage pics) | PriusChat
    The yellow bolt seems the location of the jack. It almost behind the front wheel. I can't even get my 2.5Ton jack under that.
    #10 FireFire, Aug 19, 2015
  11. Mendel Leisk
    40,515
    Ah woops, no I was talking regular Prius. And I was so sure. :ROFLMAO:
    Thanks for the link, very nice pics, and yeah you're right, that yellow bolt location must be it. I looked at the Prius c owners manual for comparison. Hopefully running up onto 2x8 pieces will help you.
    #11 Mendel Leisk, Aug 20, 2015
