2015 Prius ICE didn't kick on during acceleration up to 43mph... fluke?
Discussion in 'Gen 3 Prius Main Forum' started by E46Prius, Aug 21, 2015.
  1. E46Prius
    E46Prius Active Member
    314
    219
    Costa Mesa
    This has happened before but at a slower speed. Today I pulled out onto the main road and car accelerated leisurely as usual. It was strangely quieter than normal though... I look at the speedo and I'm already past 15 mph and nothing. Just electric acceleration. I press the gas harder and now I'm into the PWR range (almost to the very end but not quite) and the car just continues to build speed but no ICE kick on as usual. at around 43 mph I get concerned and floor it all the way to see if the engine would kick on and finally the gas engine kicks on. It's as if the electronics of the car fell asleep. The acceleration felt labored as only the electric motor was providing power and I'm sure it's not good for the battery to put that much strain on it at those speeds. For those interested, I was in normal mode. Not EV, not ECO, not PWR. I stopped at the light then pulled off and the car took off and ice kicked on as normal (7-8 mph). The car behaved normally for the rest of my drive.
    Has this happened to you before? Is this a known glitch? An "Oh yeah us prius owners experience that from time to time" scenario? I'm sure if I take it in, they won't be able to "duplicate" the problem. It's funny when I press the EV button, and I go past 8mph or so, the car beeps (excessive speed indicator) and the ICE kicks on. But here I am doing 43 mph with the pedal almost floored and no ICE.
  2. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    It is strange. Was the HV battery full (last 2 bars filled)? I've had occasions where the HV battery was that full but on hard acceleration the ICE always comes on, just doesn't do a lot.
  3. fuzzy1
    10,337
    I'll also suggest that the HV battery was nearly full, engine fully warmed, catalyst warmed, etc.
  4. E46Prius
    314
    219
    Costa Mesa
    The car was fairly cold. Sat about 2 hours after my commute home. Then started it to run an errand a block away (wash the car) and started it again to go home and that's when it acted funny. Battery indicator showed one bar above half way.
  5. Tideland Prius
    16,493
    That's weird. Usually it happens if the battery is full (8 bars) or the car is cold (but at this time of year, 2 hours after commuting shouldn't cool it down that quickly). If the engine is cold (say below freezing or colder), yeah the engine will stay off and you'll be powered by battery only so that part is normal (if your engine really was cool).
  6. E46Prius
    314
    219
    Costa Mesa
    ^ Interesting. So there are normal scenarios where the ICE won't kick on even up until 40+mph? That seems strange for me and quite abusive for the battery pack. But if it's within Toyota's normal parameters then I won't be too concerned.. I'll definitely keep an eye on it..
