Featured SPOTTED! *UNWRAPPED* 2016 Prius spotted this morning!
Discussion in 'Gen 4 Prius Main Forum' started by Sporin, Aug 21, 2015.
  1. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
    Thank you both. Jdonalds, did you mean to share an image/link? Not seeing it.
    Nevermind, found it. Amazon code isn't working.
    #541 vinnie97, Aug 26, 2015
  2. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    Interesting. I can see the link in my own post. Here is the product "
    BAFX Products - Bluetooth OBD2 scan tool - For check engine light & diagnostics - Android ONLY"
  3. Mendel Leisk
    40,459
    Speaking of spare tires and safety: a fair number of PIP owners are buying spares, and carrying them loose in the hatch area. I hate to think what they'd do in a crash.
  4. El Dobro
    El Dobro A Member
    7,071
    3,258
    4 inches?
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,030
    Westminster, Colorado
    I didn't measure it, but I could touch both seats at the same time with my thumb and ring finger, and I have small hands.
  6. bisco
    51,021
    front seats were all the way back and rear seat was all the way forward.
  7. bisco
    51,021
    take one off the potato. if i stop posting, you'll know what happened.
    btw, have any of the safety agencies tested a loose spare int the hatch, in a 55 mph crash?
    JTM2955 likes this.
  8. Mendel Leisk
    40,459
    Good idea. It might well be corralled by the rear seat back, but I wouldn't count on it. :eek:
  9. bisco
    51,021
    what happens when folks load there cars for bear when they go on vacation?
  10. 70AARCUDA
    70AARCUDA Active Member
    845
    209
    Tucson, AZ
    ...during any frontal accident, a 'loose' doughnut tyre will become a rubber sandwich!
  11. JTM2955
    JTM2955 Active Member
    475
    185
    I doubt it. Let's see, put a 50 to 60 lbs projectile loose in ANY car. It's a killer.
    Why not a Continental kit? You could put the license plate in the center of it or above it. It would offer crash protection instead of a crash projectile.
  12. mozdzen
    mozdzen Active Member
    719
    295
    Phoenix
    2015 Tesla Model S
    For the record, I don't like multi-quote.
    One flat I got was in the middle of the desert where no cell phone service was available. If i could pump the tire with goo, that would have worked. That was on a gravel road. I don't travel on that road at night, or anytime where changing tires would bum me out.
  13. mozdzen
    719
    295
    Phoenix
    2015 Tesla Model S
    buy your own and put it in the damn trunk like "old time cars".
  14. mozdzen
    719
    295
    Phoenix
    2015 Tesla Model S
    Nevermind - death object in a high speed crash. Just latch it on the roof to add character to the car.
    JTM2955 likes this.
  15. JTM2955
    475
    185
    Like a Land Rover. Above and beyond..
  16. Mendel Leisk
    40,459
    Spend 30 grand on car and then start cobbling together a spare? Not happening.
  17. Tideland Prius
    16,428
    And in certain European countries, you're required to carry spare light bulbs (one headlight, one indicator, one brake light) and a high visibility jacket. (It's also one reason why MB has a feature that uses the nearest equivalent bulb if the car determines one of your lights is blown)
    We've had a flat with every car we've own (just one and no more lol.. weird). Never had to use the spare. The one time I actually tried swapping the tyres and the tools that Toyota gave me couldn't even get the lug nuts off the alloys so even with a spare, that was no good.
    Yup. I'm an urban driver. If I have a flat, I pump up the tyre and drive to the nearest automotive shop to have it plugged. Rural drivers should carry a spare.
    You can also partially quote posts so you don't have to quote (or multi-quote) the entire long post if you only wanted to respond to a portion of it. Simply highlight the words and when you let go of the LMB, a small pop-up will appear asking if you would like to add it to a multi-quote or simply reply to those selected words immediately.
    It is. The spare is heavier than the stock alloys.
    Honda did that with the Fit (the last gen. I don't know if they did the same for the latest one that was just launched). Honda did the mpg test and everything without a spare tyre and then offered it as a dealer-installed accessory.
    Good quality tyres won't save you from screws! But yeah at least you have a fighting chance.
    One trick that I remembered from a video a long time ago is to buckle the rear seatbelts, particularly the rear centre one to minimise the chance of cargo going in between the split folding seats (which is the weak point since the edge of the seat backs have the latch to hold it back).
    If you really want to cover your bases, use the straps that are included with the Prius to secure the rear seats. Tie each end to the D ring at the back of the cargo area (the D rings closest to the rear seatback) and loop the strap around the rear seat (so it goes into the passenger compartment side of the seatback). This works if you have a lot of smaller items that the strap may not hold back so it's easier to secure the seatback instead of the cargo. If your cargo is large, then you can wrap it around the cargo within the cargo area.
  18. Mendel Leisk
    40,459
    Tideland I won't even attempt to quote you, especially on an iPhone. That's hands down the MOTHER of all multi quotes. Anyway:
    Regarding your difficulty loosening lug nuts, I'll bet it's due to "pros" rotating your tire with air tools doing final torque.
    If torqued to around 80 lb/ft, it's no problem, especially if you partially loosen while car is on ground still.
  19. Tideland Prius
    16,428
    :D:D:D
    I was a couple of pages behind on this thread :whistle:
    Yeah you're right. It's most likely the technicians using powered tools when they do the tyre rotations.
  20. DavidA
    2,341
    1,817
    Chicago western burbs
    Everyone knows the only proper way to stow a spare tire is on the side with buckled leather straps and above/within the running boards. Like this:
    Trollbait and Mendel Leisk like this.
