"Replace engine / inverter coolant" easy or hard?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by thebardksu, Sep 10, 2015.
  1. thebardksu
    thebardksu Junior Member
    Denver CO
    Hi All,
    I have a 2008 Prius with 100,800 miles on it and I am planning to do the 100k maintenance. The maintenance guide says to “Replace engine/inverter coolant”.
    My question is, is this something I could easily do myself? I am an engineer, though this doesn’t translate into being super handy with cars ha J. Aside from a couple oil changes, a battery change, and replacing some interior items on a couple cars, I don’t have much experience working on cars.
    How much would it cost someone else to do the work? And if this is what is recommended is this something just about any shop can do or will this require a dealership visit?
    Thanks!
  2. CooCooCaChoo
    CooCooCaChoo Senior Member
    954
    533
    Cow-lee-fornia
    2023 Prius
    For the second gen Prius' there was a recall effort to replace the inverter coolant PUMP because of premature failure. Is this the item you are referring too? The coolant for the inverter/engine is different from that item and are themselves in different reservoirs and must be serviced individually.
    If you do the research, you will find that drain and refill of both coolants (they use the same Toyota Red, just different reservoirs) is quite simple.
    The inverter pump itself is a bit more involved, but there are videos on YouTube showing how it can be done.
  3. thebardksu
    Denver CO
    No this isn't for the pump. This is just for the maintenance item that requires you to just replace the coolant fluid. I will check out the videos to see how easy/hard it would be. If too hard (if I don't have tools, etc), then I'll need to call around and see how much it would cost. Anyone have an idea of what a good price for this should be?
  4. Mendel Leisk
    41,302
    Dealerships will give you a price, try them first?
    I've changed coolant on various Hondas over the decades, never any issues. But the Prius makes me nervous, not sure if I'd take it on. Apparently very fussy.
  5. Patrick Wong
    18,200
    6,500
    My posts 22 and 42 in the following string explain how to replace the engine coolant. For North American 2G Prius, this is not quite as easy as some may think due to the presence of the coolant heat recovery system, and a few PC members have posted that their local Toyota dealer service dept failed to do the job correctly, mostly due to not getting air out of the system.
    Changing engine coolant | Page 2 | PriusChat
    The yellow Lisle funnel is really helpful to make this job easier than it otherwise might be, and I highly recommend it.
    Some owners resort to performing a partial drain, just at the radiator, without draining the CHRS canister. However this is inadequate as only ~1/3 of the coolant will be replaced. Even if all three drain cocks are opened, only ~2/3 of the coolant will be drained as the remainder is trapped in the cabin heater core due to the presence of the engine coolant valve, the pump that moves coolant through the heater core when the engine is off, etc.
    The 2G inverter coolant drain and replace is not particularly difficult assuming you have a 24 mm socket and can find the correct drain plug on the transaxle case. You don't want to drain the transaxle ATF accidentally. The bleed valve for that system is hiding under the large black plastic panel that covers the radiator.
    As an engineer, you would benefit from access to the factory repair manual information, which you can access at techinfo.toyota.com
    My guess is that you would pay ~$200 for the dealer to drain and replace both coolants. You need three gallons of Toyota Super Long Life Coolant, which will cost ~$65 or $70.
    wrothgar likes this.
