oil pan gasket change 2011 prius
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by frank99, Sep 21, 2015.
  1. frank99
    frank99 Junior Member
    sheridan ar
    can anyone help on the skill needed to change the oil pan gasket on my prius , some what skilled and have the tools , car stands , etc search for a vid, but know luck, thanks to all frank
  2. ForestBeekeeper
    ForestBeekeeper Active Member
    765
    301
    Maine
    Mine had to be replaced once while still under warranty. It took the dealership 5 hours to do it.
    Last month during routine servicing they said that it will need to be replaced again soon. They quoted me $1200 to do it.
    My Prius is not losing enough oil to measure any loss.
    frank99 likes this.
  3. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    Should be no different than any other car:
    1 - Drain oil (replace oil filter while your at it)
    2 - Remove oil pan bolts/Remove oil pan
    3 - Remove old gasket (thoroughly clean both surfaces)
    4 - Install new gasket (use recommended gasket sealant, if any)
    5 - Replace oil pan
    6 - Install oil pan bolts to proper torque spec (don't know what it is for your model year - use alternating tightening pattern)
    7 - Replace oil drain plug with new gasket to proper torque spec
    8 - Fill with recommended amount of oil
    9 - Run engine and check for leaks
    frank99 likes this.
  4. frank99
    sheridan ar
    RR, that first statement is very true, but prius guy said silicone stuff would haft to dry, would rtv red work or is this something like the light bulbs a few years back, 100$ for the bulb and 300$ labor. 1-9 is perfect but scared of the silicone stuff or gasket the prius guy talk about, 3 hours to dry???? thanks frank
  5. bisco
    51,037
    is there a problem with 2011 oil pan gaskets?
  6. frank99
    sheridan ar
    hope not , on # 2 prius and first repair on both
    #6 frank99, Sep 21, 2015
  7. bisco
    51,037
    i never saw it on my '04, 08', and current, funny that forest beekeeper is looking at his second one.(n)
  8. RRxing
    2,530
    1,806
    NEPA
    If it takes 3 hours to dry, it takes 3 hours to dry. If that's what the directions say, follow the directions, and factor in the extra time it takes. Might as well do it right...
    frank99 likes this.
  9. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    778
    514
    Outside Philly, PA
    I think the idea is you apply the sealant and reassemble everything, leave it to set up for several hours, and then torque everything to spec to get a good seal on the pan.
  10. bisco
    51,037
    might be why they're failing?
  11. Mendel Leisk
    40,492
    Seems pretty straightforward. One hour labour, two at the most. There's no mention of waiting for sealant to set up, in fact they say to assemble within 3 minutes of applying sealant. The car should sit for a couple of hours post-install. Obviously an oil change too, lol.
    From the Repair Manual:
  12. ForestBeekeeper
    765
    301
    Maine
    That might explain why it took them 5 hours the last time, 3 of them were waiting to cure. But they want to charge me for the full 5 hours of bay fees.
