Check how many miles per Gallon q
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by DDK, Sep 24, 2015.
  1. DDK
    DDK New Member
    La Mirada
    How can I check to see how many miles per gallon that I'm getting?
    PRIUS PLUGIN 2012
    Thanks
  2. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    Welcome to Prius Chat.
    I believe you might have better luck if you ask this question in the plug in forum. Here's the link. Toyota Prius Plug-in | PriusChat
    Best of luck to you (y)
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Go to EV Driving Ratio screen. Take the gas miles divided by gallons consumed.
    In this example screen, 2,202 gas miles / 37 gallons equals to 59.5 MPG.
  4. bisco
    51,843
    and make sure you reset the evdr1 or 2 for the intended measurement, trip, tank, lifetime.
  5. angelahortega
    angelahortega Junior Member
    28
    Ukiah
    Every time I fill up I reset the odometer
    I then take the number of total miles driven and divide it by the 8 gallon
    It's an 8 gallon tank. I do this before the next fill up
  6. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Since that includes electric miles, the result is not fuel economy but rather "gas consumption". PiP calls it consumption MPG.
    To get gasoline fuel economy, take only the gas miles and divide it by 8 gallons.
    Ditto for electricity fuel economy, electric miles divide it by kWhs.
  7. Mendel Leisk
    41,328
    Simplest method, works for me, bullet-proof, and will circumvent the absurdly optimistic mpg indicators built-in.:
    1. Fill tank. Note odometer reading.
    2. Drive until it's running low, as much as you're comfortable with.
    3. Fill tank. Note odometer reading.
    4.Subtract first odometer from second.
    5. Divide the resulting distance by the gallons of gas at the last fill up.
    Comments:
    a) How low you run the tank is arbitrary, no need to run it extremely low.
    b) Using consistent fill technique will help avoid vagaries in individual tank calculations.
  8. bisco
    51,843
    it's not an 8 gallon tank.
  9. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
  10. bisco
    51,843
    exactly.
  11. bisco
    51,843
    perhaps he meant, 'it took 8 galleons to fill the tank'.
  12. Mendel Leisk
    41,328
    Galoots?
  13. bisco
    51,843
    galbraith's.;)
  14. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    For future reference, any time you hear something per something else, the "per" indicates that you divide. In this case Miles Per Gallon, or miles divided by gallons.
    It's one of the most useful mathematical ways to determine the relationship of 2 or more things. I often calculate calories per dollar, or calories per weight or volume to maximize my food purchasing power.
  15. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Ya but gallon is not the only fuel used here.
  16. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    Unless the grid electricity is translated into gallons, hence - MPGe.
    When I am calculating my food purchasing power I am not calculating it based on Carbohydrates calories only.
  17. bisco
    51,843
    been a week since the o/p. i wonder if he's counting calories?
  18. Redpoint5
    1,026
    509
    Portland, OR
    Yeah, the OP asked about MPG, which has nothing to do with electricity. Only 1 post from them, so we don't get a clarification to their question.
    ...and I don't count my calories, I just eat them. My preference is to eat them as proteins and lipids, but those are usually more expensive than carbs.
    Some people live to eat, and others eat to live. I'm the latter.
  19. usbseawolf2000
    14,487
    3,001
    Fort Lee, NJ
    Then leave out the electric miles from dividing with gas gallons.
    MPG means fuel economy of gasoline, nothing to do with electric miles driven with electricity.
    I think you are referring to "consumption MPG" (not fuel economy). That's the total miles driven with gas gallon. PiP clearly differentiate that on the screen. There is no need to calculate.
    Which is why I think OP was asking gas fuel economy. That needs miles driven with gas.
  20. bisco
    51,843
    the o/p's question was answered in post #3, as is usually the case in these tangent threads. he probably got what he wanted and moved on.:cool:
    usbseawolf2000 and Redpoint5 like this.
