Tire Damage
Discussion in 'Gen 3 Prius Main Forum' started by JStrenk, Sep 30, 2015.
  1. JStrenk
    JStrenk Active Member
    203
    101
    Ravenna
    I just had my Prius in for a rear wheel bearing replacement when the mechanic told me the tire was cut to the core in two places with chunks blown out. It still held air though. They are about 10" Apart
    What could cause this?
    There are no cuts on the front tire. I would think that with that amount of damage, both tires on that side would show some damage.. Vandalism?
    I run about 40 PSIG in the tires. Just put them on this spring.
    The tire was showing some cupping around the outer edge I thought was from the wheel bearing.
    So I was going to replace the tire anyway. But this was a surprise.
    #1 JStrenk, Sep 30, 2015
  2. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    That's pretty incredible - you are lucky they noticed it! I would take it back to the dealer who originally sold you that tire.
    matt b. likes this.
  3. JStrenk
    203
    101
    Ravenna
    I just sent Tirerack an email with pictures of the damage. I'll see what they say.
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Road debris? Glass? Metal? Lumber (with nails)? Do you recall driving over something (wooden palette?) - it would surely have made a loud noise! I would think wrong place for vandalism (vandals would have gone for the side-walls!) Good luck! I'd be interested to hear what Tirerack think! - Wil
    PS: Any hazard insurance on your tyres? (often an option when they're purchased new)
  5. JStrenk
    203
    101
    Ravenna
    I Don't remember anything like that would of certainly checked the tires if I did :) and only the rear tire has damage.
    and they are 10" or so apart. So I don't see it being a pothole or anything like that.
  6. xliderider
    xliderider Senior Member
    8,140
    3,274
    Honolulu, HI
    Do you run the car through automated car washes?
    I've seen tire damage caused by the track mechanism that moves the car through the tunnel. In one case, the tread was damaged similarly to yours, but not quite as deep a gouge. And I believe it was front tire damage.
  7. JStrenk
    203
    101
    Ravenna
    Occasionally. And it sometimes does push on the drivers side rear tire...
    I guess it would depend upon what tire it caught when starting..
    Hmmmm..... There is only one place were I get the car washed when I'm to busy to do it myself ...
  8. ETC(SS)
    7,134
    I think I can rule out vandalism.
    Mind you, it's only a guess but I think that tires are a little easier to damage by knocking a hole in the sidewall where the tire is a little thinner.
    I'm guessing FOD for the tread damage.
    Bearing replacement??!!
    On a 2011???
    I've seen Priuses knock down hundreds of thousands of happy motoring miles on the OEM bearings.
    What happened to yours?
    Autocross?
    Driver's Ed car?
    Wheel/tire mod gone wrong?
  9. JStrenk
    203
    101
    Ravenna
    Don't know why the bearing failed. I notice it when I was replacing the brake disk. It didn't move freely like the other side.
    The passenger side would spin freely with a little push and this side would not.
    Here: Are the rear hubs suppose to turn freely? | PriusChat
    Consensus was brake dragging overheated the hub.
    I am an X-autocrosser so my driving style somewhat reflects that...:)
    #9 JStrenk, Oct 1, 2015
  10. Mendel Leisk
    41,321
    There's been a fair number of third generation owners posting here about replacing bearings. It was something new to me, but then we've never been high mileage users, with Honda for decades. Had CV joints go bad once.
  11. David Beale
    David Beale Senior Member
    5,963
    1,988
    Edmonton Alberta
    If it was a cut it should be more or less straight. That looks more like a crack, with the crack weakening the tread blocks that came off. I would guess contaminant during molding, or unfinished mixing of the rubber compound.
  12. Toasty
    Toasty Junior Member
    35
    Chattahoochee Hills, GA
    looks like road damage
  13. JStrenk
    203
    101
    Ravenna
    I just remembered, my son drove the Prius over a stop sign and a NG gas line vent last summer..
    Maybe that caused it..
