is 10% increase on EPA cycle realistic?
Discussion in 'Gen 4 Prius Main Forum' started by cyclopathic, Oct 1, 2015.
  1. Lee Jay
    Lee Jay Senior Member
    5,850
    4,029
    Westminster, Colorado
    How many people buy four-door hatchbacks for sex appeal?
    If that's what you want, buy a Vette. I buy this car to haul my stuff and my family, efficiently, at modest cost, and with little or no hassle. Period.
    And Steve's changes didn't get me to buy any Apple stuff - I didn't have any before he came back, and I haven't bought any since.
    50,820
    we're talking about glove boxes because toyota hasn't told us much else. but if you look back at the 3rd gen release, the talk was pretty much the same, 'looks don't impress me', 'don't like the bridge', mpg increase isn't as much as expected', 'handling, acceleration, soundproofing, seats aren't much better'. nothing new under the sun, you guys must be newcomers.:cool:
  3. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Well the aerodynamic resistance in city driving is negligible, and on EPA highway is less than 1/2, so you need to double for this reason. Also take into consideration rolling resistance and other parasitic losses, aero-resistance will be a portion of total on highway too. So x4 times isn't a bad approximation.
    Here is a calculator take a look: Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com
  4. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    Battery development will always be evolving newer materials, process, more power, less wgt, size, and recharge time. Costs, reliability, and recycling will also be a never ending process also.
    DBCassidy
  5. cyclopathic
    3,292
    547
    2014 Prius c
    I think EPA test still uses 55MPH speeds, and for 3200-3300lbs Prius (curb+driver) with Cd=0.25 rolling resistance and aerodrag level up at 45MPH. At 55MPH aerodrag accounts for 59.43%. And highway rating is only 45% of overall combined rating; other 55% come from city driving which is not influenced by aerodynamics. HWFET also emulates acceleration, braking, etc. A/C drag will not get 10% lower just b/c you improved car aerodynamics by 10%.
    If you ignore other aspects (A/C, weight, etc) and only accounting for rolling resistance and aerodrag, to see 1% improvement in combined rating you will need to improve it by 1/0.45 * 1/0.6 = x3 times. Add A/C, other aspect and x4 does not look that far off.
    I do not think we will see new Prius Cd <0.2 needed to achieve this goal. Reducing Cd to 0.2 will reduce aerodrag to 53.95% at 55MPH (6% reduction). Which would have <2% on combined rating.
    So there are only two logical conclusions: 1) they will not get 10% improvement; 2) they found it somewhere else (like duping EPA city rating FTP-75 test via software optimization).
    #25 cyclopathic, Oct 2, 2015
  6. mozdzen
    mozdzen Active Member
    719
    295
    Phoenix
    2015 Tesla Model S
    A. New tire spec: Inflate to 44 psi.
    B. New software spec: enable cheat mode when mpg test track is detected.
    Ooops. Scratch B. VW ruined that one for us.
    tpenny67 likes this.
  7. cyclopathic
    3,292
    547
    2014 Prius c
    I am not sure that it is a real cheat like in VW, just falls into grey area.
    With CVTs and drive by wire manufacturers are known to "optimize" setting for EPA tests. If you compare many cars with auto and manual on fueleconomy.gov, autos are getting better MPG ratings than MT. Yet, independent real life tests show this is not the case.
    I suspect Toyota could let the battery run lower or use more aggressive settings for short period of time. Not really a cheat, just taking advantage of fixed duration EPA test. Driving Prius C vs Gen3, I can tell that C does better in short stop and go, but if you really get stuck it is not any better than Gen3. Yet it is rated higher in City driving than Gen3.
  8. cyclopathic
    3,292
    547
    2014 Prius c
    UPDATE: Ken is saying staff manual lists Cd,=0.24. This is a 4% improvement over Gen3, so it will give 1% overall boost to combined MPG.
  9. Lee Jay
    5,850
    4,029
    Without knowing frontal area, you can't make that claim.
  10. cyclopathic
    3,292
    547
    2014 Prius c
    2016 Toyota Prius details leak in manual, returns 40 km/L
    0.48% less
  11. Lee Jay
    5,850
    4,029
  12. cyclopathic
    3,292
    547
    2014 Prius c
    So on JC08 Gen4 is 21.7% better than Gen3? Since JC08 is centered around city cycle, we can expect similar showings on EPA city. Even if highway rating will go up by modest 5% (4% engine efficiency and 1% aerodrag) we can expect close to 14% overall rating improvement.
    62 city/ 50 hwy
    57MPG combined??
  13. cyclopathic
    3,292
    547
    2014 Prius c
    the profile on Gen3 and Gen4 isn't drastically different, how much more precision on top of 0.5% do you need?
  14. Lee Jay
    5,850
    4,029
    Your 0.5% is probably +/- 5%, at least.
  15. Mendel Leisk
    40,245
    Guilty as charged, I just came onto the Prius scene late in the 2010 model year. We managed to snag a 15 month old "new" car, about 10 km's on the odo. Something the salesmen neglected to point out, but hey, it's worked out great, knock-on-wood.
    So I wasn't aware of 2nd to 3rd gen transition, pushback, that sort of thing. But I can imagine it. Was it as vehement as the current debacle, do you think?
    If there is this sorta tearing-and-healing of expectations with each generation, it's debatable that we're actually progressing, that it's becoming a "better" car. It's evolving, that's for sure.
    One thing, that's largely unspoken I think: the Prius is a BIG part of our lives, more so than a regular car. And when Toyota comes along willy-nilly with a new rendition, that just might bomb, there's consternation, justifiable I think. Well, unless we wean ourselves.
  16. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    This proves (again) that you cannot make a reasonable judgment and build theories on partial facts.
    This whole thread should have been titled: What you anticipate (wish/unwish) will be the EPA rating of Gen 4 - place your bet here.
    Not more than a betting game (which is fine - as a game).
  17. cyclopathic
    3,292
    547
    2014 Prius c
    Well we don't really know until official EPA numbers are out.
    I am not hang up on numbers one way or another, just trying to understand if it is possible, and where it comes from.
  18. civicdriver06
    civicdriver06 Active Member
    797
    324
    Germany
    Those numbers in the manual are definitely wrong !
    Why would they decrease max . system power output ?
    To get better fuel economy?
    The new Toyota Auris Hybrid refresh in Europe allready gets 3.6 Liters on 100 Km which is about 65 mpg,but since European cycle is a bit unrealistic ,it would probably about 54 mpg US rating .
    So if even the "old" HSD with 136 hp is capable of getting quite realistically 54 mpg,,why would it take such a downsize of the power train to squeeze just one more freaking mpg out of the vehicle ?
    We will have to wait and see what happens on Oktober 29.,but I am quite sure I'm right !
    #38 civicdriver06, Oct 2, 2015
  19. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    The Auris HSD is a smaller and lighter vehicle, isn't it?
    #39 giora, Oct 2, 2015
  20. bisco
    50,820
    perhaps we're a more passionate bunch, or perhaps it's like this on every car site, idk. but with prius, it's hard to improve on perfection, so expectations may be a bit unrealistic. if you took everything everyone wanted in all these threads, you'd need a gazillion models.
    giora and Mendel Leisk like this.
