First i had it, now i don't!
Discussion in 'Gen 2 Prius Main Forum' started by aarons12, Jun 23, 2004.
  1. aarons12
    aarons12 New Member
    704
    long island, NY
    Well, i DID get my prius last week. then i parked it in my driveway, which goes all the way to the back of the house. Then the work crew doing some minor work at our house came along and plopped a dumpster NEXT TO THE HOUSE, ON THE DRIVEWAY!! So now, my prius sits all alone on the driveway, blocked in by the dumpster!
    (don't feel too bad for me, i could have them move it if i really wanted but it's really the best place for the dumpster and i still have my 02 buick... still, frustrating) :wink:
  2. SAPrius
    SAPrius New Member
    137
    San Antonio, Texas
    Ow! Just reading about it makes me feel "down in the dumps" too!
  3. Batavier
    Batavier Member
    442
    The Netherlands
    Well, at least you can still sit in it! :D
  4. jchu
    jchu New Member
    1,063
    Nampa, ID
    Manny wouldn't have anything to do with the dumpster placement would he?
  5. LewLasher
    LewLasher Member
    244
    66
    Cambridge, Massachusetts
    2019 Prius
    XLE AWD-e
    I thought you were going to say that they placed the dumpster on top of the Prius.
    See, things could have been worse.
  6. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    And think of the high MPG you'll get while you're doing it!! :mrgreen:
  7. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    :lolup: :lolup:
    Manny's a criminal mastermind, and his minions are everywhere.
  8. bruceha_2000
    bruceha_2000 Senior Member
    3,054
    302
    Northwest VT
    2018 Prius Prime
    I think the next thing you must do is build a block wall at least 10 feet higher than the roof peak around 3 sides of the car, otherwise the contractors might accidentally throw or drop construction debris on it!!
  9. jfschultz
    jfschultz Active Member
    639
    115
    Germantown, TN
    2020 Prius Prime
    Be careful! It might be Manny's tactic to be sure you are home when he gets there with his nail puller.
  10. Danny
    Danny Admin/Founder
    7,093
    2,118
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    :lolup: :lolup:
    I too thought it had dropped on your car, but that would have been too easy for Manny. He wants to see you suffer by being able to see the car but not move it.
    Brilliant!
  11. aarons12
    aarons12 New Member
    704
    long island, NY
    you know, i never even thought of that. hmmm
    anyway, one thing i gotta remember is to start and run the thing. the dealer warned me that it can drain its own battery from the electronic gadgetry if you don't use it for over a week...
  12. efusco
    efusco Moderator Emeritus
    19,891
    1,196
    Nixa, MO
    Nah, not in a week unless there's something wrong with the 12v battery already. I've left mine sitting for 10 days on several occasions with no ill effects. 2 weeks would probably be pushing it a little...3 is definately risky, esp. if you don't turn off the SS/SE and such.
    This might be a good excuse for you to consider adding a solar trickle charger for these longer times 'at rest'. There's an older thread here where I talk about mine--where it came from, how I hook it up, etc.
    Also, I assume you already know, but there is No Risk at all to your Traction Battery unless you're going to leave it sitting for many months.
  13. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    If you disable your SE/SS system (there's a switch to do so), this should reduce the pull on your battery significantly.
    See this thread for details.
  14. aarons12
    aarons12 New Member
    704
    long island, NY
    thanks for the battery advice guys. i started it up today and it ran for a couple of minutes so i should be fine. it should be out and about sometime next week when they remove the dumpster.
    maybe i will disable the se/ss though, that can't hurt.
    the solar trickle charger is an interesting idea. i use a plug-in 'battery conditioner' on my avanti so it's always ready to rock and roll!
