Slip indicator light when going about 60mph
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Grayson73, Oct 8, 2015.
  1. Grayson73
    Grayson73 Junior Member
    62
    Maryland
    My Prius touring had 4 205/55/16 tires. I had the mechanic change the front two tires to 205/50/16 and now, whenever I drive over 60mph, the slip indicator light flashes continously. When I slow down, it goes away.
    Is it because the front and rear tires are mismatched? If so, I'll have the mechanic change the rear to 205/50/16 as well.
    Update:
    The mechanic tried many combinations and said these combinations work:
    205/55/16 in the front and 205/50/16 in the back
    205/50/16 front left and rear and 205/55/16 front right
    205/55/16 all four
    I assume that this means that the sensor is only on the front right and it won't take 205/50/16. Why is that?
    #1 Grayson73, Oct 8, 2015
  2. WilDavis
    WilDavis Senior Member
    2,493
    2,154
    49
    I would think that mis-match might very well cause the problem you describe, I bet the ABS monitoring computer is getting confused with the apparent different speeds at which the wheels are spinning, and thinks "Ah, slippage! DANGER! Will Robinson! ICE! That's what it has to be!" Of course if the control software had been tested more thoroughly, this would have been seen as a possible scenario in QA, and the tyre size (…and thus speed) would have been factored into the software!
    #2 WilDavis, Oct 8, 2015
  3. Grayson73
    62
    Maryland
    Update:
    205/55/16 all four
  4. WilDavis
    2,493
    2,154
    49
    I'm at a loss for an explanation, but all I can say is The ChuggyPig is shod with identical Michelin Energy Savers on the original 16" rims for the warm part of the year, and I've just ordered a set of 4 Blizzaks to be put on the 15" steel rims for the snow season, and the only time I've noticed the "DANGER, Wil Davis! There is slippage in the traction sytem!!!" light, is occasionally when I've been on black-ice, or on painted lines or metal man-hole covers on the road! (You just get used to it!) :rolleyes:
  5. xliderider
    xliderider Senior Member
    8,041
    3,213
    Honolulu, HI
    It could be due to the sensor, maybe it's just more sensitive to speed changes than the others. I believe aftermarket sensors are pretty inexpensive, if you want to see if installing another one has hopefully, a better outcome.
    WilDavis likes this.
  6. HGS
    HGS Member
    307
    123
    The Gen 3 Prius has a wheel sensor on each wheel. I assume the Gen 2 is the same. Even my 17 year old truck has 3 sensors (1 on each front wheel and 1 on the rear axle.)
    You should have 4 tires of the same size for the ABS to work correctly.
    WilDavis and milkman44 like this.
  7. HGS
    HGS Member
    307
    123
    The 2008 Prius does have 4 wheels sensors. Here is a parts catalog showing all four parts:
    08 2008 Toyota Prius ABS Speed Sensor - Brake - Beck Arnley, Standard Motor Products, Front Left, Front Right, Rear Left, Rear Right - PartsGeek
  8. WilDavis
    2,493
    2,154
    49
  9. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    Yer lucky it's just a sensor going off, once had to while changing wheels on a gen 2, (the tech broke a bead) run two different sizes front and rear, at 30 mph the ice died, it would run at 29 fine, ignore that particular mechanic that advises different sizes front and rear;)
  10. dolj
    dolj Senior Member
    8,190
    4,169
    Wellington, New Zealand
    OP, I'd go further and say ditch that "mechanic" and find a new one.
  11. HGS
    HGS Member
    307
    123
    Though the same size tires should be used, it's a little lop sided running the donut spare. I don't remember off hand the maximum speed with the spare tire.
  12. WilDavis
    2,493
    2,154
    49
    Isn't it marked on the side-wall?
  13. HGS
    HGS Member
    307
    123
    Yes it is. I just didn't want to walk outside to my car and take a look. It's probably about 45 mph. Wild guess.
  14. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    don't blame the mechanic unless he suggested running mismatched tires. there is no good reason to run different sized tires on a prius. they will turn at different speeds, and as you've seen the traction control won't like it.
  15. Grayson73
    62
    Maryland
    Thanks for all the replies! Right now, I'm running 205/55/16 in the front and 205/50/16 in the back, no issues. One day I'll replace the front with 205/50/16 and hope that I don't have an issue. I find it odd that having mismatched 205/55/16 and 205/50/16 in the front had no issue while having 205/50/16 for both front tires had issue.
  16. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    There is no problem using using either size providing all 4 tyres are the same size. It is worth noting however that 205/55/16 will give a more accurate speedo reading, and are also surprisingly considerably cheaper to buy.
    The OEM 195/55/16 size gives a speedo reading about 3% faster than actual speed. Tyre dia 24.4 inches
    The 205/50/16 will give a reading about 4.6% faster than actual speed. Tyre dia 24.1 inches
    The 205/55/16 will give a reading about 1% faster than actual speed. Tyre dia 24.9 inches
    Calculation for tyre dia is:- Tyre width (205mm), x aspect ratio (55%), convert to inches divide by, (25.4) to give sidewall height, x (2) number of sidewalls in the diameter, + (16) the wheel size.
    Alternative use one of the many online calculators.
    Tyre sizes vary slightly by manufacture, and by the amount of ware.
    John
    #16 Britprius, Oct 13, 2015
  17. Grayson73
    62
    Maryland
    Thanks. That's why I bought 205/55/16 the first time. However, this time, 205/50/16 was cheaper for the Bridgestone Ecopia EP422 Plus (VR). I got 4 for $286.
  18. vaughnstark777
    180
    33
    Roy, WA
    2001 Prius
    I
    This happened to me after I reset my ABS/VSC System with my tech stream. Same tires as I’ve always had since I got it. It’s only as I approach 60mph, the light starts flashing and it acts as though I’m loosing power, like it would when the traction control kicks in when the front wheels start to spin? Weird.
  19. ChapmanF
    17,235
    You can use Techstream to look up the reasons for the most recent four (I think it's four) times the traction control was triggered. It will have the vehicle speed, g forces, speeds of all four wheels, etc. That will probably bring you very close to a conclusion on what's going on.
    When you say you "reset" your "ABS/VSC System" with Techstream, what did you do exactly? And was there a reason you did that?
  20. mr_guy_mann
    mr_guy_mann Senior Member
    3,950
    1,903
    NJ-USA
    Try ChapmanF 's suggestion to see what data you can get to figure a diagnostic direction. Top of the list is something funny with a wheel speed sensor. While that could be a sensor itself is glitching, it could also be that the front and rear sensors are reporting slightly different speeds, and the difference between those speeds is great enough at 60 that it triggers the traction control.
    So if the event data record suggests that wheel speeds triggered T/C, you might want to look at tire condition, and try rotating them front to back. Yes, they are the same tires that you have had for awhile, but if the fronts have been on the front the whole time then they could have worn down more than the rears to the point that it's just past the T/C trigger threshold at higher speed. Not super likely (if all the tires are the same brand and size), but possible.
