Older safari no longer renders
Discussion in 'PriusChat Website Questions' started by bwilson4web, Sep 16, 2015.
  1. Former Member 68813
    3,524
    983
    US
    yup, same here. BTW, my chrome is up to date and it's the second most popular browser.
  2. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    The same issue has risen again: the forum overview is blank. I did just update Flash before, so maybe that is the culprit.
  3. DavidA
    2,342
    1,818
    Chicago western burbs
    My old Safari is rendering just fine here.
  4. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    Just a short time ago, I fully uninstalled Flash from my computer. If I need that crap for something, I can use Chrome. Safari's been working fine ever since, just a bit faster, no weird reloads.
    Flash is now on 10% of the Web, and still dropping. A few years late, but better late than never.
  5. bwilson4web
    16,114
    YEaaaaaHHaaa!! It works!
    I had checked on a thread over in the TDI forum and on a whim, thought to try PriusChat with my older Safari and it works!!
    Now I understand there are no guarantees and it may break again at anytime. It could be those 'flash' advertisements have moved on. It could be allowing more than just TLSv1. I'm just sharing a moment of joy as my older browser is working again.
  6. DavidA
    2,342
    1,818
    Chrome, as of 6pm tonight, renders very strangely. Also, I can't get to the splash page.
    #26 DavidA, Apr 26, 2016
  7. bisco
    51,501
    having the same problem with safari. suspect that dannys under the hood, bleeding the brakes without tech stream.
  8. DavidA
    2,342
    1,818
    Works again now. Weird.
    EDIT: Whoops - down again. Splash page not opening. Can't post to several threads.
    EDIT2: 6 hours later, all seems to work again
    #28 DavidA, Apr 26, 2016
  9. bisco
    51,501
    whew, that was bad! still taking forever to post.:mad:
