  1. s2kinfinite
    s2kinfinite Junior Member
    I agree NOT worth it...seeing many people fubar it.
    Dylan Doxey likes this.
  2. xliderider
    xliderider Senior Member
    8,085
    3,237
    Honolulu, HI
    Make sure you get the 3M exterior mounting tape, the dark gray/black double sided foam with the red backing film. Don't get the regular strength white foam tape, it won't hold up to the outside conditions and it's hold isn't strong enough.
  3. slowpriusj
    slowpriusj Active Member
    167
    271
    Brunswick, MD
    Drove my fat Prius on a different route and got this! 141000 miles image.jpg
    Accordlayingkit and sfv41901 like this.
  4. JarrettOriginal
    116
    81
    North Hollywood
    85 days after purchase, I finally received my California Plates!
  5. SwamppThingg
    SwamppThingg Active Member
    235
    443
    Mount Prospect, IL
    I guess from what I just read its actually "nano ceramic" by a company called solarfree?
    It's all the shop I went to does.
    It was cheap and has a lifetime warranty so I just went for it. The great reviews on yelp told me it was okay.
  6. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    Would you happen to know of an install video that includes the relay harness? I have a general idea of where everything goes (I'm going to keep the ring terminals on the wiring) but just want to verify.
  7. xliderider
    8,085
    3,237
    Honolulu, HI
    This post has a link to a good text write-up of where everything goes. And a picture of a bolt in the engine fuse box that you can put your ring terminals under for +12v (it's always hot, treat it like it's the positive terminal on your battery, disconnect your 12v battery in the back before messing with it).
    TRS Morimoto Elite H11 HID kit issue
    s2kinfinite and HelloHybrid like this.
  8. saulbassfan
    saulbassfan Senior Member
    979
    3,108
    Southern California
    Ah man, I feel like my plate is taking forever. Looks good!
    Dylan Doxey, sfv41901 and HelloHybrid like this.
  9. fopoku2k2
    fopoku2k2 Member
    292
    60
    Columbus - Ohio
    Where did you order them from?
  10. Blizz Pearl Brady
    Blizz Pearl Brady New Member
    Cali
  11. HelloHybrid
    482
    1,483
    Thanks man! I saw your Instagram before, you ordered the 60s plate as well right? The lady at the DMV said everyone's plates are coming in slower than usual. I ordered mine back in May and I just got the notice on Wednesday to pick them up, even though the ETA when I ordered said 8-12 weeks. Hopefully yours come soon. It'll definitely look good on your car!
    saulbassfan likes this.
  12. HelloHybrid
    482
    1,483
    You'd order these things through your State's DMV. There's usually a page on their website to configure your plate and order it. For CA it's an extra $40~ to your annual registration.
    fopoku2k2 likes this.
  13. HelloHybrid
    482
    1,483
    Found the start of @Dylan Doxey 's paintball gun mod when people piss him off. :ROFLMAO:
    slowpriusj, Dylan Doxey and sfv41901 like this.
  14. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    That would be awesome
    A Blizzard Pearl against a Winter Gray Metallic Prii
    VS980 4G ?
  15. Sean Callahan
    Sean Callahan Senior Member
    314
    582
    Honolulu
    Yes I am on bags, you shouldn't of needed rolled or pulled for that width and offset. I'm running 18x9.5 +30 which is extremely aggressive for stock fenders on a Prius. I had them pulled and rolled all around. What coils are you running? I'm still trying to sell my RSR Black-i coils. They were great and offered pretty much as low as you wanted to ever go. Excited to see what yours looks like.
  16. Starbrand
    Starbrand Senior Member
    493
    1,502
    Westmont, IL
    LOL I can visualize the lineup of the WGM and Blizzard Pearl Owners in my head and doing knockout rounds! I think you guys outnumber us though.
  17. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Yesterday I swapped out my hids since one burnt out with halogens. Also learned a damn rat chewed my fog light wire that goes behind the engine through the firewall which explains why they were flickering for the last 2 months. Thankfully out of the apartment and outdoor parking and into a house with garage..get to rerun new wire now
    Fone ?
    HelloHybrid likes this.
  18. el Crucero
    el Crucero Senior Member
    1,628
    699
    Inland Empire
    Amigo, my vanity plate took 97 days to arrive. Be patient, it will come soon. :coffee:
  19. DFW
    DFW Member
    39
    31
    Dallas
    Lol...I got RSR black-i, too.
    A little lower than I wanted as mud flaps scrape on speed bumps.
    #9379 DFW, Oct 18, 2015
  20. HelloHybrid
    482
    1,483
    Got the HIDs in before it started raining. Ran into issues with the relay harness though so I currently don't have one. I ended up cutting the ring terminal off and replaced it with a push on. Plugged it into 1 of the 2 empty ports towards the rear of the fuse box, grounded it with the chassis bolt near the edge of the engine bay, etc... Couldn't get power to the bulbs even in the Ready mode. I plugged into the OEM wiring just to test the ballasts/bulbs and everything was working fine. Any ideas what went wrong? I'd like to run it with the harness since the majority of you guys recommend it.
    slowpriusj, sfv41901 and SwamppThingg like this.
