12V battery study
Discussion in 'Gen 3 Prius Technical Discussion' started by szgabor, Oct 22, 2015.
  1. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    I have started taking measurements of my 12 V battery ..
    The car is almost 3 years old (about 2 weeks left)....
    The methodology is that I open the trunk first, measure the open circuit voltage, then start the car and measure the starting current (this part is not very precise since I have to open the driver side door start the car and then return to the trunk to watch the meter which takes different times every time).
    Anyway, I record the "starting" current and wait till engine stops (full warm up) and record the current at that point. It is usually going down gradually during the warm up and
    Also record time ambient temperature and whether or not the car was driven more then an hour before the measurement.
    I am not sure if I should/could record anything else, and how to represent/interpret the data.
    Here is the initial table
    Date Driven Open Voltage Start Current A Current A Ambient Temp F Comment
    1 10/7/2015 8:00 am y 12.57 5 2.34 60
    2 10/7/2015 6:00 pm y 12.67 10 2.5 75
    3 10/8/2015 8:00 am y 12.60 7 2.2 65
    4 10/8/2015 6:00 pm y 12.71 n/a 0.9 78
    5 10/9/2015 8:00 am y 12.61 7 2.5 65
    6 10/10/2015 11:20 am y 12.54 5.7 1.6 60
    7 10/11/2015 8:00 am n 12.52 4.8 2.0 68
    8 10/12/2015 8:00 am y 12.43 13 10 60 found one of the door open overnight;left the car running another 10 min at that time Current was 8.22 A
    9 10/13/2015 8:00 am y 12.76 3.5 1.72 64
    10 10/13/2015 6:30 pm y 12.81 12.50 2.2 77
    11 10/14/2015 7:50 am y 12.69 5.7 1.3 59
    12 10/14/2015 6:30 pm y 12.65 5> 2.10 75
    13 10/15/2015 7:50 am y 12.70 5.5 1.12 55
    14 10/16/2015 7:55 am y 12.66 8 2.3 57
    15 10/16/2015 7:00 pm y 12.75 11+ 3 73
    16 10/17/2015 10:30 am y 12.65 6.5 2.06 59
    17 10/19/2015 8:15 am n 12.48 n/a 0.75 37 too cold to charge or error ???
    18 10/20/2015 8:05 am y 12.71 6.5 2.2 52
    19 10/20/2015 6:20 pm y 12.76 8+ 2.8 70
    20 10/21/2015 7:45 am y 12.76 7 1.7 54
    21 10/21/2015 6:00 pm y 12.72 10 3.0 73
    22 10/22/2015 7:50 am y 12.64 7 1.20 55
    will add data as i am going alone ... any comment would be appreciated.
    #1 szgabor, Oct 22, 2015
    50,816
    wow! i check mine once a month or so. i open the hood the night before and check the jump point in the morning. it's been 12.7 since i started checking in april 2015. it's 42 months old.
    Robert Holt likes this.
  3. Mendel Leisk
    40,242
    I find after sitting overnight, the battery will be at some point, say 12.8. If the car isn't driven over the next few days the voltage will slipslide a bit more, say down to 12.6.
  4. CR94
    CR94 Senior Member
    2,658
    1,147
    Northwestern S.C.
    What exactly is the goal of the study? If I understand the procedure, you're simply measuring normal recharging current at two times shortly after awakening the car. The much higher currents after the door was left open are to be expected, although it's surprising that the voltage wasn't lower that time. Battery drain with any door (including hatch) open is about 0.7A, plus current to power whatever light bulbs are on.
  5. macman408
    1,179
    367
    +1 on the door... If you really want an unloaded voltage measurement, you should measure under the hood so you can do it with no doors open. For added accuracy, pop the hood when you're done driving, or at least do it from the passenger's side (so you don't open the driver's door and start the brake pump) and then wait a minute or three to let the battery recover. But as long as you're consistent in how you measure the voltage, it at least tells you something.
    What are you using to measure the current? Do you have a clamp on one of the battery cables?
  6. David Beale
    David Beale Senior Member
    5,963
    1,985
    Edmonton Alberta
    The other thing wrong is the "starting current" is actually a 50Amp pulse, about 0.5 second long.
    Your readings indicate your 12V battery is in good shape.
  7. bisco
    50,816
    because there is so little required of the battery, i believe a simple resting voltage is all that's needed. eleven years of experience hasn't proved me wrong, but i have never had to deal with a battery that measured in the mid to high 12's, but wouldn't power up the car.
    CaliforniaBear likes this.
  8. szgabor
    994
    175
    Oceanside NY
    I am trying to catch the "misterious" mpg drop for charging the weakening 12V battery (which i do not beleive). This is the baseline so I know what is the normal current in a relatively OK battery
    You are right about the initial current before driver door opened seem to be btw 650-800 mA
    Anyone knows how the ECU decides to drop the chargin voltage from 14.3-ish to 13.6-ish ... so far ALL of the above data point was taken in Park mode with the 14.3 V I do not have meter which can continually record the current for a given period ... that would be interesting to catch the voltage drop.
  9. szgabor
    994
    175
    Oceanside NY
    That "starting current" is explained ... yes I can not record (alone) the real starting pulse I am just recording the number I see first getting back to the trunk...
  10. szgabor
    994
    175
    Oceanside NY
    I am uploading pics about how I measure ...
  11. szgabor
    994
    175
    Oceanside NY
    Here is the way I do the measuring I have the cargo stuff out for now makes it easier. (don't need the stuff)
    #11 szgabor, Oct 23, 2015
  12. szgabor
    994
    175
    Oceanside NY
    Thanks I know all this ... but currently i am parking on the street (and public garage during the day hence the afternoon measures) so popping the hood overnight is not an option ... maybe if I (ever) clean the garage.
  13. CR94
    CR94 Senior Member
    2,658
    1,147
    Northwestern S.C.
    It's very difficult to catch a mythical creature. Even if in mediocre condition, the 12-V battery won't absorb enough energy to affect fuel consumption noticeably, at least not directly.
    The recharging currents you're measuring are in the opposite direction from the brief 50A or so discharge that boots up the hybrid system.
    Another easy way measure battery voltage without the door-open drain is to fool the switch for the hatch by manually pushing the latch into its fully closed position (two clicks) while the hatch is actually open, then measure at the battery.
    Good question about the voltage change. Temperature reported by the sensor near the battery is probably one factor in that decision.
  14. bisco
    50,816
    if i forget to pop the hood the night before, i reach over through the passenger door.
  15. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    The easiest method to monitor energy use is to buy a $10 ELM237 Bluetooth device and then run Torque on an Android phone to see the traction battery output current.
    With my PiP in park, but in the Ready state, I typically see 1.1 amps. Turning on the headlights increases this to around 1.6 amps, but it fluctuates. What is the resting voltage of the NiMH traction battery? (found out it's 202 volts) Is it the same as the Li-Ion traction battery (found out it's 346 volts)?
    Once my 12v battery gives out, I'll replace it with LiFePO4 to marginally improve efficiency and weight, and hopefully significantly improve longevity. It might even be cheaper compared to what Toyota wants for their OEM battery.
    #15 Redpoint5, Oct 26, 2015
  16. BobMc989
    BobMc989 Junior Member
    35
    17
    North Mississippi
    You could have it load tested at a dealer or any shop, battery retailer etc. with the right equipment, just a thought.
  17. Toppcat
    Toppcat Member
    223
    69
    Northern California
    The prius 12v system doesn't demand much current to operate, thus it doesn't need a big. Battery!I had a 2014 subaru xv crosstrek hybrid. It had 2 12v battery 1 for the 12v system and 1 for the stop start system, the stop start was recharged by the hybrid battery inverter , every morning the hybrid battery was or almost depleted, the cycles that battery go thu I bet you that won't last for 3 years! I expect the prius battery should last me 5-8 years! I am thinking about replacing the prius battery w a agm battery cause I replaced the subaru 2 batteries w agm batteries,
  18. Toppcat
    Toppcat Member
    223
    69
    Northern California
    And I noticed headlights was brighter, faster engine restarts, maybe slight mpg increase? And never had a depleted hybrid battery from the inverter re- charging the stop start battery .
