RPM signal for each engine
Discussion in 'Gen 3 Prius Accessories and Modifications' started by TheFenux, Oct 29, 2015.
  1. TheFenux
    TheFenux Junior Member
    31
    Oklahoma City, OK
    I'm trying to add two tachometers to my 2012 Prius, one for each engine. I've been combing through diagrams and circuits and getting a headache. Can someone point me the where I might find that signal? Is it only available through the OBD-II connector? I'd test what Techstream can tell me, but I let someone borrow my cable.
    Any hints or answers would be very appreciated.
  2. JimboPalmer
    12,470
    6,877
    Greenwood MS USA
    I have never heard of a Prius with two engines, did you mean two motors?
  3. Maarten28
    Maarten28 Active Member
    415
    224
    Netherlands
    I suspect he means the ICE and MG1 (since MG2 is fixed to the vehicle speed). To my knowledge the only way to get these (without adding own tach sensors) is using the OBD2 port. But that has the added bonus that you can hook up a tablet of any size and use that as a dashboard.
  4. mrbigh
    3,686
    699
    Long Island, NY
    and the second engine is...............? for the back-up generator like in the VOLT?
    I think you are in the wrong forum..
  5. Mendel Leisk
    40,939
    Please please please, call it the "engine", or we'll never get anywhere. :)
    There's only one RPM value available on the On Board Diagnostics port. You can read it with ScanGauge I know.
  6. fuzzy1
    10,337
    But my ScanGauge has three RPMs programmed in: ICE, MG1, and MG2. The first is built in, the later two are Prius-specific Xgauges taken from a spreadsheet somewhere on this site,
  7. awallin
    awallin New Member
    helsinki, finland
    The dashboard on all toyota hybrids should have a "nerd mode" like this!
  8. CR94
    CR94 Senior Member
    2,676
    1,159
    Northwestern S.C.
    My Prius is so basic that it has only one engine.
    When you know the speed of the car and the speed of the engine, you can easily compute the speeds of both MG1 and MG2.
