Difference in Distance to Empty and actual miles driven
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by MPK2015, Oct 21, 2015.
  1. MPK2015
    MPK2015 New Member
    Woodbridge nj
    I am new to this forum. Just got my CPO 2012 Prius plug in
    I am driving the 2012 CPO Prius plug in since last friday and noticed few thing that are not consistent with the miles i am driving.
    My office is 67 miles one way.
    Today morning my Distance to empty showed 291 miles.
    When i parked in office parking garage the Distance to empty was on 185 miles.
    i drove 67 miles but the distance to empty dropped by 291-185 = 106 miles.
    Let me know why that is happening or should i go to a dealership for check up.
    Is that thing covered under the electronic package purchased?
    I am kind of worried about this as its been just 6 days i have had this vehicle and seeing this thing
    Don't know what to do?
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Distance to empty, is not a consistent measurement in relationship to the miles you've driven.
    A hybrid use a gasoline engine, electric motors and a battery all in "synergy" to create the great gas mileage.
    But how far you can go on X amount of gas can really change and vary depending numerous variables. How much electric driving you can do (gas not burning), how cold it is outside, engine burns more gasoline warming up, Uphill driving, flat, downhill, short trips vs. highway...
    So anyway, Distance to Empty becomes an ever changing estimate.
    I don't really pay much attention at all to cruising range, or distance to empty until I get down to the last pip on the gas gauge.
    But I've seen it work both ways. In other words, I've seen it say I had 20 miles left, and then I've driven farther than 20, and it still shows I have miles left to go...and I've seen it drop faster in relationship to how far I've actually driven.
    I use distance to empty as simply a tool to determine when I should actually fill up. On my Prius reaching Zero is conservative, and I still have nearly always a gallon or more of gas left, but I use Distance to Empty as a "nice" point to actually fill up.
    It has never been an "Iron Clad" representation of actual miles to emtpy, nor an accurate measure of how miles I've actually driven vs. what it says I have left. I don't think this is a flaw or problem.
    As long as your odometer is reading accurately, and your gas gauge is reading accurately, DTE and Cruising Range, are just estimates. I think you are fine.
    monskie15 likes this.
  3. bisco
    51,843
    congrats and welcome! all the best.(y)
    MERGED
    the closer you get to zero, the more accurate it becomes. watch your gas gauge, when you get down to 2 bars, fill up. thats about 6 gallons. if you like taking risks, you can go down until the last bar starts flashing. thats about 8 gallons. then there's still 2 gallons emergency.
    #3 bisco, Oct 21, 2015
    BobMc989 likes this.
  4. Mendel Leisk
    41,328
    Maybe analogous to file downloading? The estimated time to download is always shifting, depending on current download speed. Maybe think of it like that?
    Personally I pay no attention to that info, just keep an eye on the gas gauge.
    giora likes this.
  5. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    As said above, don't worry it's only an estimate
    With the plug-in, i have seen distance to empty estimate going up even. After several trips all in EV it can update upward.
  6. bisco
    51,843
    if you drive about the same all the time, it gets really accurate.
  7. MPK2015
    MPK2015 New Member
    Woodbridge nj
    Thank you all for the update.
    That is very helpful. I am kind of relieved now.
  8. Camfab
    Camfab Member
    124
    36
    2014 Prius Plug-in
    Mine has always been way off as well as the EV mileage estimate. The most interesting thing I've noticed is this....... If I drive conservatively the Average fuel economy is relatively accurate. If I drive aggressively the Average fuel economy shown only drops a few miles per gallon. It's completely inaccurate. It's almost like Toyota has built in some manipulation of the fuel economy info....... Manufacturers would never cheat like that.......
    Just ask Volswagen.
  9. giora
    giora Senior Member
    1,966
    730
    2013 Prius Plug-in
    This is not cheating, it is far from it.
    The estimate tries to predict EV distance of your next trip based on history with more weight to recent history. This is the best estimate the system can give.
    Don't expect the system to predict the aggressiveness of your next drive, it is not a prophet.
  10. Mendel Leisk
    41,328
    I see an overall positive 7.5% positive bias in what Toyota tells me for mpg, compared to calculated. Variation as low as 5%, as high as 9%.
  11. BobMc989
    BobMc989 Junior Member
    35
    17
    North Mississippi
    Welcome MPK2015 ,that's good info. on the fuel left thanks Bisco
