better MPG in ambient temps of low 60's vs low 70's (F)
Discussion in 'Gen 3 Prius Fuel Economy' started by Former Member 68813, Oct 30, 2015.
  1. Former Member 68813
    3,524
    983
    US
    why is it? seems contraintuitive. for the record i get worse MPG in 80's and above (AC) and 50's and below (heating).
    Edit: this is based on city commuting, pulse/glide, garaged overnight. rains excluded (much lower MPG).
    #1 Former Member 68813, Oct 30, 2015
  2. Mendel Leisk
    40,472
    The one time you shut off AC? AC imposes a mpg penalty.
  3. Former Member 68813
    3,524
    983
    US
    no, i don't use AC in low 70's.
  4. qdllc
    qdllc Senior Member
    1,371
    399
    My first guess is the impact of AC/Heat. Maybe the temperature affects the road surface in a way that reduces drag/rolling resistance?
  5. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I've noticed the same thing. There's probably half a dozen factors.
  6. Former Member 68813
    3,524
    983
    US
    like what? lower battery temp and more battery utilization?
  7. Former Member 68813
    3,524
    983
    US
    weird how people don't want to talk about it. is it some sort of a taboo?
    case in point: the last 2 days were cold, daytime temps in high 50's/low 60's and i'm getting the best mpg since getting new tires a year ago, near 60 mpg. up to now, i averaged 55 mpg. now, my car is garaged, so it doesn't get a cold soak overnight, so this may make some difference.
  8. bisco
    51,028
    i think because most of us don't see it, we're baffled.
  9. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    Wish I had systematic data but don't.
    But my impression has been better mpg as temperature increases up until the low 70s where we start using the AC, which clearly negatively impacts efficiency.
    I had assumed lower energy losses due to lower friction, hysteresis, and cold start losses as temperature increases.
    Will pay more attention to see if we recreate your pattern.x
    Pale Fox likes this.
