Outside temp kicks engine on?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Greg_M, Nov 17, 2015.
  1. bisco
    51,842
    that sounds like a good one.
  2. giora
    giora Senior Member
    1,966
    730
    Herzliya, Israel. Car: Euro version GLI
    2013 Prius Plug-in
    I am sure you will love it - it's a great car.
    The FAQ sticky thread in this forum has a lot of info for a new user.
  3. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    What's this 32ºF you speak of? I thought temps like that only happen in the freezer section.
    LOL
    OK, so once or twice a year - generally the dead of winter - my route to work takes me through an air-drained canyon. On those days, the temp can get to be below 32ºF. When it does, the car always sends an alert. So reading that particular temperature is hard-wired into at least one sensor. That's a section that I'm always on EV, but my engine has always warmed up plenty before that section - as in a 25 mile drive at freeway speed warmed up. As a result, I don't recall that my ICE has ever kicked back on.
    So perhaps a cold engine in combination with the freezing temp is necessary for the ICE to kick in.
  4. bisco
    51,842
    yes, we're talking about the first combustion of the day, not after it's warmed up. and please stop rubbing it in.:cool:
  5. mrlebop
    mrlebop Member
    136
    68
    My ICE comes on when the temp drops below 40-ish outside almost immediately or if I have the heater or fan on, and then turns itself off after a mile or so, so I'm never completely EV in colder weather.
    #65 mrlebop, Dec 1, 2015
  6. mrlebop
    mrlebop Member
    136
    68
  7. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    The heater will Always turn the ICE on. The engine coolant supplies the heat.
  8. CaliforniaBear
    1,180
    289
    Northern California
    That has never happened for me. However it never gets very cold here and the car is always in the garage at night.
