Alignment?
Discussion in 'Gen 2 Prius Technical Discussion' started by grasshopper, May 5, 2006.
  1. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    I have a 2006 with 2000 miles on it. I noticed that the steering wheel was not centered when I was going straight. So I took it to my local Toyota dealer and had it aligned. I ask that they give me a little positive toe in, but that didn’t happen. Anyway, this is the print out and I just wondered if one of the tech’s could look at it and tell me if it looks ok. I wouldn’t trust my local Toyota dealer to screw my gas cap on correctly. But he’s the only one I have within 3 hrs one way in this state. I guess that’s why he can be such a jerk!
    I actually have no way of knowing if this is a print out of my alignment.
    Thanks
    Grasshopper
    [attachmentid=3238]
  2. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    well it looks like every alignment sheet DH has ever shown me... i don't know the actual spec numbers but i can ask him to look at it tonight.
  3. upland_bill
    upland_bill New Member
    I am contempating an alignment as well. When I drive on the highway, my 2005 meanders a bit in the lane. I was wondering if it was really necessary to have Toyota do it (i.e. is the alignment special in some ways), or should 'any' wheel/alignment place do?
  4. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    <div class='quotetop'>QUOTE(upland_bill @ May 5 2006, 01:43 PM) [snapback]250329[/snapback]</div>
    I would say that any good alignment shop could do it. My Prius is new and the alignment was free, so thats why a Toyota Dealer did it.
  5. tomdeimos
    tomdeimos New Member
    995
    Lexington, MA
    Alignment requires a Toyota THHT. So any shop with one could do it but this usually means a Toyota dealer.
  6. galaxee
    9,810
    471
    MD
    thumbs up from the tech. it was done on a dsp600 or dsp800 machine. the nice thing about those machines is you have to intentionally f it up to get it wrong.
    you need to reset the zero point calibration after doing an alignment or the traction control kicks in because it thinks you're turning when you're not.
  7. 200Volts
    200Volts Member
    439
    46
    Northern CA
    I disagree, from a subjective POV.
    First, your right rear is WAY too positive. Funny, this was out on my 04 as well. Aske the dealer to order a shim kit and realign at no charge.
    This caused me to have to replace the right rear wheel bearing-hub-abs sensor at 76k miles.
    Second, your front toe is set to almost zero. I have had 3 back to back alignments and found higway tracking was best when front toe IN was 0.005 to 0.01(max limit). Yes, it makes a difference I can feel.
  8. matteo
    matteo New Member
    <div class='quotetop'>QUOTE(grasshopper @ May 5 2006, 10:04 AM) [snapback]250296[/snapback]</div>
    Same thing here.
  9. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    <div class='quotetop'>QUOTE(200Volts @ May 10 2006, 05:00 PM) [snapback]253075[/snapback]</div>
    Thanks for the input. I requested some toe in but the dealer didn't do it. They really sux. :angry: I'll check with a toyota dealer in the next state and see if he can spell service. The closest dealer besides my local dealer is in the next state, about 1.3 hrs away.
    Grasshopper
  10. ciparis
    ciparis New Member
    25
    Mill Valley, CA
    I'm wondering if my '06 needs a look. It's hard to say, given that it's fine most of the time.
    The problem is that above, say, 65 MPH, it's *really* twitchy. The lightest touch causes an overly sharp turn in that direction, making it pretty hard to control at higher speeds on the highway. 65 and under, and it feels fine.
    It's a new 3-week old car, and I had the stock tires replaced with Comfortread before I accepted it (since the attrocious tire noise on the crappy California grooved highways was the only thing I disliked about the car during my test drives).
    Should I have it checked? And if so, what should I have them pay the most attention to? The local dealer's service dept seems very accomodating and thorough.
  11. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    <div class='quotetop'>QUOTE(ciparis @ May 31 2006, 11:57 PM) [snapback]263841[/snapback]</div>
    I dropped my tire pressure to 40/38 and had to pay to have my car aligned for the second time at another dealer because the first didn’t do what I ask. But the toe in and the tire pressure change made a difference. I couldn’t find anything about any shims for the rear wheels and was looked at as a pain in the nice person know it all when I ask. But then I have a problem with almost all car dealer service personnel because they give me the same old razz-a-matazz. Anyway, back to the question. If indeed you have a good service dept. at your dealer, (if so you are incredible lucky) then I would get it aligned and request a little toe in. Make sure to inflate or deflate your tires to the proper PSI or you may need to fight about them saying that is the only problem and you don’t need an alignment. Check your steering wheel, maybe it is not exactly straight and then they will be forced to do an alignment.
    Break a leg. B)
  12. ciparis
    ciparis New Member
    25
    Mill Valley, CA
    Welp, they did it, and though I had to go through the "Where did you hear that, on the INTERNET?! Har Har" routine, I ended up with .03 and .04 toe in on the left/right front. I can now drive on the highway at 75+ without feeling like I'm fighting to maintain control (or dangerously close to losing it).
    My rear camber is -2.5 / -0.4, rear toe is .17 / .18 -- should I be concerned about those?
  13. galaxee
    9,810
    471
    MD
    grasshopper: shims are approved on a case by case basis by SET, which is the reigning empire in the southeast. afaik, they only approve them for cases where the wheel is out of the 'acceptable' range.
  14. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    <div class='quotetop'>QUOTE(ciparis @ Jun 2 2006, 01:28 PM) [snapback]264723[/snapback]</div>
    I don't know, but I had three people at the Toyota service dept. standing around me explicitly telling me, as if I were a child, that there was no adjusting of the rear wheels. I ask what the tolerances were but they would not give me an answer. I ask if I knocked the rear out of alignment just a little, how would they know if it was out if they didn't know what the tolerances were. There response was that if it were bent then it would be so far off that it would be obvious. That’s when one of them said in a low voice "the internet is a dangerous thing." So I left. :angry:
    The reason that I think they don't like the internet is two fold. One is that they probably need to spend a lot of time with customers convincing them that the info they received is bogus when indeed it is bogus.
    The other reason is that it's much more difficult to lie to the customer, witch makes there job much harder because they need to actually know what there talking about. Except where I live because my local dealer is the only dealer within 1 ½ hours drive one way and that dealer is actually in another state. Unfortunately, they also are out in the middle of nowhere and have no reason to give good service because who wants to drive 3 to 5 hours one way (the next clostest dealer) just to get your car checked.
    Which brings me to the question: are most Toyota Dealers unable or unwilling to give good service or am I just lucky? And do they go to training to learn how to be so arrogant? :eek:
    The truth is that I liked Toyota a lot more before I bought one ....... and the problem is not the car.
    <div class='quotetop'>QUOTE(galaxee @ Jun 2 2006, 01:36 PM) [snapback]264728[/snapback]</div>
    Thanks galaxee. I have more info and questions:
    What is the acceptable range?
    what is a Toyota THHT?
    What is dsp600 or dsp800 machine.
    My toyota dealer used a Hunter alignment machine, so was up wit dat? :huh:
    Is it going to be nessesary for me to become Certified just to oun a Prius.
    Or will just being Certifiable be enough? :blink:
    I'm begining to hate Toyota. :(
  15. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I just had my Prius aligned, four times. The first time was at a tire store where I planned to buy new tires. They discovered that the rear toe was out of spec and said "no adjustment better take it to the dealer."
    I went back to the dealer where I bought it and they said there was no problem with the rear but adjusted the front toe because they said it was toed in to far. When they finished the car was so screwed up it would hardly go in a straight line, before they adjusted it there were no serious tracking problems
    I Went to another dealer (Campbell Toyota in Hermiston, OR) they agreed with the tire store. They put the front toe back where it belonged and called Toyota about the out of spec rear toe. Toyota said "put in a new rear axle beam." I now have a new axle in the rear and everything is A-OK with the alignment. None of this has cost me anything except my time which I don't mind because I'm retired.
    Both the tire store (Les Schwab) and Campbell Toyota got it right and they are both using Hunter alignment equipment. I don't know what the other dealer is using, when I called them to tell them their equipment might have problems they became quite defensive.
    I just bought a new set of tires from the Les Schwab dealer (Toyo Proxis TPTs) and my next Toyota will almost certainly come from Campbell Toyota.
  16. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    <div class='quotetop'>QUOTE(tumbleweed @ Jun 2 2006, 05:28 PM) [snapback]264848[/snapback]</div>
    Thanks for the info.
    Just wondering, did you get a print out? If so could you post it?
  17. tumbleweed
    4,067
    692
    Eastern Oregon
    <div class='quotetop'>QUOTE(grasshopper @ Jun 2 2006, 02:35 PM) [snapback]264851[/snapback]</div>
    Yes I did get print outs from Campbell Toyota and Les Schwab, the other Toyota dealer wouldn't provide one because their printer was broken and they said it "cost to much" to replace it. That should have been a red flag for me!
    Unfortunately I don't have a scanner but I will give you the as left data from Campbell, this is how it is now with the new axle beam:
    ***********FRONT: LEFT*************************FRONT: RIGHT
    Camber*********-0.7*********************************-0.6
    Caster***********3.2**********************************2.8
    Toe*************.03**********************************.03
    *********************************FRONT
    Cross Camber***********************-.01
    Cross Caster*************************0.5
    Total Toe****************************0.05
    *************REAR: LEFT*****************************REAR: RIGHT
    Camber***********-1.5**********************************-1.3
    Toe***************0.18**********************************0.05
    ***********************************REAR
    Cross Camber************************-.02
    Total Toe****************************0.23
    Thrust Angle**************************0.07
    Before the new axle beam was installed the left rear toe was 0.35, the spec is 0.03 to 0.28. It didn't cause any problems as far as drivability was concerned but it might have caused excessive tire wear. I'm glad I was able to get it fixed before I put new tires on.
    EDIT: Well that didn't work so good, when I posted it all my spaces were taken out.
    There maybe that will work, just ignore the ****.
  18. ciparis
    ciparis New Member
    25
    Mill Valley, CA
    I'm really curious about rear camber.
    Mine is:
    Left: -2.5
    Right: -.4
    Cross camber: -2.1
    Specified range for this is 0.5 to -0.5 ...should I get this fixed? It's actually listed in red on the Toyota alignment report.
  19. 200Volts
    200Volts Member
    439
    46
    Northern CA
    Grasshopper,
    If you're stuck with a bad dealer, then go over their heads.
    Ask for the Toyota Regional Service Manager, or some such title. Gather all your documentation of who you spoke with, when and what they told you. Forward this info to him and see what his response is.
    Tracy Toyota in Northern CA is great. They told me about the shim kit, gave me a rental for a day when it came in and my car was back in the shop. They gave me the print outs of all my alignments. They even replaced the right rear wheel bearing (many miles after the shim kit was installed) that failed because of the out of spec factory alignment.
  20. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    <div class='quotetop'>QUOTE(200Volts @ Jun 6 2006, 01:52 PM) [snapback]266746[/snapback]</div>
    Thanks for the advice 200volts
    That’s very good advice, but I worry about pi—ing them off. Kind of like sending your burger back because it wasn’t cooked the way you ask. Next thing you know your burger tasts a little like saliva. :eek:
    Just curious, why isn’t it 220 volts? :huh:
