2004 Prius Ticking
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by TwoPriusInTenn, Nov 28, 2015.
  1. TwoPriusInTenn
    217
    60
    Tennessee
    I have a 2004 Prius that has a ticking noise coming from the engine compartment It speeds up and slows down with the idle of the engine or the pressing of the accelerator. Appears to be coming from the passenger side (US). No diagnostic codes have come up. Any ideas?
  2. ETP
    2,802
    1,170
    Auburdale FL
    Just watched Hook. Has it ticked its last tock?
    Regular engines it would be valve tick but a Prius is not a normal engine. How many miles on it?
    Mine has a very quiet tick at 66K. If everything else is good drive the wheels off it. It may not be hurting anything else.
    Also check your accessory belt.
  3. bisco
    51,023
    agree, it could be a valve tick.
  4. TwoPriusInTenn
    217
    60
    Tennessee
    Everything seems to be fine other than the tick at 234,000.
    Love the Hook reference!
  5. bisco
    51,023
    you can pick up a low miles engine for cheap, if it becomes too annoying. are you burning any oil between changes?
  6. darkgiant
    darkgiant Member
    287
    42
    Seattle
    I have essentially this same clicking noise in my 2007 Prius, due to the winter weather here, I haven't gotten a chance to properly record the sound but once I wrap up with classes in a few weeks, I really want to get around to recording the noise and posting it on here and getting some feedback.
    Originally, my mechanic said it could be the bearing (my noise is very obvious from the front passenger side too), but the noise only appears when I accelerate pretty heavily, otherwise, when I am going downhill, or on a flat road slowly accelerating you can't hear a thing. For me, the car though doesn't act funny in any way aside from this clicking noise.
  7. bisco
    51,023
    which bearing, wheel?
  8. darkgiant
    darkgiant Member
    287
    42
    Seattle
    Yep, the passenger wheel bearing.
  9. TwoPriusInTenn
    217
    60
    Tennessee
    Yes, it is burning some oil.
  10. bisco
    51,023
    i'd keep an eye on it. can the valves be adjusted?
  11. darkgiant
    darkgiant Member
    287
    42
    Seattle
    Hey, so I am almost done with finals :) Once I have a clear day, I will record the sound from my 2007 Prius and share.
    Just out of curiosity (and not trying to hijack this thread), but how much does a Prius engine replacement cost? My current mechanic does the job of course, but just curious how much the part, and labor would cost. Of course, I'd imagine it being done at any Toyota $tealership, it can easily ring up to four digits...
  12. ETP
    2,802
    1,170
    Auburdale FL
    put in 0W40 or 5W30 and check back with us.
  13. TwoPriusInTenn
    217
    60
    Tennessee
    I am currently running 5W30 Synthetic.
  14. ETP
    2,802
    1,170
    Auburdale FL
    OK, would not go any heavier. How is your MPG?
  15. TwoPriusInTenn
    217
    60
    Tennessee
    Thank you.
    Average mpg is 45.
  16. ETP
    2,802
    1,170
    Auburdale FL
    If it doesn't smoke and your filter is ok as well as the PCV valve if it has one????? Drive it another 100K.
    Any heavier oil will hurt your MPG. If it is really cold you might want to consider 0w30 or 0w40. And go back to 5W in the summer.
